Author Topic: added coolant capacity  (Read 15688 times)
Offline dem3500
« Reply #15 on: October 18, 2016, 08:21:14 AM »
Quote from: Skeans1;70237
I've got both bikes and a radiator out of an R, I have seen fans that were coolant temp driven before just can't remember where off hand.
i know the trx450 fans have a temp switch. that is what i plan on running along with the 450 over temp light or an electronic display of some sort so i can monitor it better.
« Reply #16 on: October 18, 2016, 08:23:05 AM »
Quote from: Skeans1;70225
Mike is on here [MENTION=486]hontrx265r[/MENTION] what about a 450 fan?
Oh cool! I didn't realize he was on here already.
« Reply #17 on: October 18, 2016, 08:23:14 AM »
Quote from: dem3500;70238
What I'm taking about is a heat energy driven fan the warm or hot coolant actually drove the fan.
Offline dem3500
« Reply #18 on: October 18, 2016, 08:26:22 AM »
Quote from: Skeans1;70241
interesting! ive never heard of that. im going to look into it
« Reply #19 on: October 18, 2016, 08:48:09 AM »
What all do you want to know for if a 450 fan will fit the R radiator? Just measurements? Voltage?
Offline dem3500
« Reply #20 on: October 18, 2016, 11:51:49 AM »
Quote from: Skeans1;70243
i want to know fittment. i know the arens has different dimensions on the two bars that are behind the radiator and go up to the upper steering mount part of the frame. ive read that people with stock frames are using a ltz400 fan but i had one of those in my hands and there was no way it would fit.
« Reply #21 on: October 18, 2016, 12:27:33 PM »
Quote from: dem3500;70245
I can get you the measurements if that helps any
Offline dem3500
« Reply #22 on: October 18, 2016, 12:30:23 PM »
Quote from: Skeans1;70246
Sure that would be great. Thanks!
« Reply #23 on: October 19, 2016, 12:33:52 AM »
Quote from: dem3500;70247
Measurements are 10 X 7.5" so for a stock style 86 radiator it'd be possible to do. As far as voltage I'll have to test it's possible they use ac.
« Reply #24 on: October 19, 2016, 01:01:38 AM »
He probably needs to know thickness Jared
« Reply #25 on: October 19, 2016, 07:04:42 AM »
Quote from: hickwheeler;70255
Forgot that measurement but on a stock frame there wouldn't be any issues or even putting a 450 radiator in place of the R radiator which is roughly 12x12.
Offline dem3500
« Reply #26 on: October 19, 2016, 07:16:12 AM »
ok thanks for the info. i dont have a stock frame............ill get it figured out. thanks for the help
« Reply #27 on: October 19, 2016, 08:53:26 PM »
Quote from: dem3500;70260
If you need a thickness measurement I can do that as well after that you're down to trying it out yourself.
