Author Topic: TRX/Zilla build  (Read 50657 times)
TRX/Zilla build
« Reply #15 on: October 16, 2016, 05:25:13 PM »
Just let all the nw guys know. Maybe get a pretty good group together
Offline Holt
TRX/Zilla build
« Reply #16 on: October 16, 2016, 05:50:25 PM »
Wow man! I would love to have that. Cant wait to see it built up to how you want it
TRX/Zilla build
« Reply #17 on: October 17, 2016, 03:05:47 AM »
Quote from: rjt500r;70174
the 250R frame  came from a member here that he built with the Zilla motor so all the work is done on the frame.
so you did get Jeremys frame.
Quote from: rjt500r;70175
Yep already been talking with him about it.
so does Arlan still have the templates or is he going all custom?
TRX/Zilla build
« Reply #18 on: October 17, 2016, 03:22:33 AM »
I have the pipe as well
Offline rjt500r
TRX/Zilla build
« Reply #19 on: October 17, 2016, 05:52:35 PM »
Quote from: Hawaiiysr;70210
I did buy Jeremy's frame. A while back Arlan was talking about getting rid of all his old templates he hasn't used in a long time but I don't know if he did or not. I did talk to him a couple of months ago and he is on board with building my pipe for the hybrid.
Offline rjt500r
TRX/Zilla build
« Reply #20 on: October 17, 2016, 05:53:42 PM »
Quote from: Hawaiiysr;70212
you have the intake for the carb I need as well!!
Offline rjt500r
TRX/Zilla build
« Reply #21 on: October 17, 2016, 05:57:03 PM »
Quote from: hickwheeler;70184
Sounds good to me.
TRX/Zilla build
« Reply #22 on: October 17, 2016, 09:57:21 PM »
Sorry for hijacking the the thread but I love your living room Josh!
TRX/Zilla build
« Reply #23 on: October 18, 2016, 03:17:15 AM »
Thanks Kevin. It's actually pretty sparse. If you seen it in person I'm sure you'd like it even more.
Offline rjt500r
TRX/Zilla build
« Reply #24 on: October 22, 2016, 10:06:36 AM »
Have the Zilla apart and the motor in the frame. Working on the front mounts. Talked with Arlan on Thursday, it will be a hand built custom pipe. Dropping it off in a couple of weeks to get the pipe built. Meanwhile a lot of cleaning and painting of parts.
TRX/Zilla build
« Reply #25 on: October 22, 2016, 10:50:53 AM »
Quote from: rjt500r;70309
What all is done to that cylinder?
Offline rjt500r
TRX/Zilla build
« Reply #26 on: October 22, 2016, 11:04:37 AM »
Quote from: Skeans1;70310
Reinforced ears and reed cage, O-ring head, head shaved, Jerry Hall dune port, V-2 reeds
TRX/Zilla build
« Reply #27 on: October 22, 2016, 12:16:23 PM »
oh nice. i believe once i get started on mine it will go together fast. my major hold up is time, and i need to assemble the motor.
TRX/Zilla build
« Reply #28 on: October 22, 2016, 01:32:11 PM »
Is it just me but seems like going to have clearance problems with the oversized tank
Offline rjt500r
TRX/Zilla build
« Reply #29 on: October 22, 2016, 02:13:52 PM »
Quote from: hickwheeler;70313
Clearance issue, yes, problem ,no. I will have to heat and reform the tank in a small spot for the spark plug. Or I could run the KTM short plug, but I will most likely reshape the tank.
