Author Topic: Jetting data base  (Read 50385 times)
Jetting data base
« Reply #15 on: July 15, 2013, 11:55:44 AM »
[h=3]JETTING: Getting the most out of your bike[/h]I have had a lot of questions in reference to my article on carburetor jetting, so I have simplified the procedures to elevate as many questions as possible.
For whatever reason it becomes necessary to re-jet a carburetor, it is without a doubt a nightmare if you do not have a procedure to follow. The following is nothing more than a technique, procedure, steps or whatever you want to call it to help identify and isolate the carburetor circuit involved.
You can only begin re-jetting your carburetor if the following conditions are met:
  • Top end is in good condition.
  • Bottom end is in good condition. Crank seals.
  • Spark plugs, air filters, reeds and so on.
If your bike's motor is not mechanically sound, then all the jetting in the world will not help. With all of the above conditions met, you should be able to jet your carburetor following these steps:
[h=3]Step 1: DETERMINE THE CORRECT NEEDLE AND OR NEEDLE JET.[/h]Whether or not your carburetor is a MIKUNI or a KEIHIN, it does not matter. This is the most important step in jetting your carburetor--period!
  • Remove the main jet.
  • Place needle clip in mid-position.
  • Start motor and run it on the stand.
Condition: Motor running and main jet out. Needle or needle jet is correct: Carburetor should run clean to approximately 3/4 throttle. From 3/4 throttle to full throttle, the motor should start to break up as a result of too rich condition.
Correction: None needed.
Condition: Needle or needle jet is too rich. Carburetor runs clean to approximately 1/2 throttle but breaks up before 3/4 throttle as a result of too rich condition.
Correction: Mikuni replace needle jet with next leaner and test again. Keihin replace needle with next leaner diameter and test again.
Condition: Needle or needle jet is too lean: Carburetor runs clean beyond 3/4 throttle and has an erratic throttle response.
Correction: Mikuni replace needle jet with next richer and test again. Keihin replace needle with next richer diameter and test again.
The emphasis here is to find the correct needle or needle jet diameter, which will allow more fuel to pass than is needed but not so much that the needle itself has no control below 3/4 throttle.
[h=3]Step 2: DETERMINE THE CORRECT PILOT JET.[/h]
  • Make sure the bike is warmed up if at all possible.
  • Main jet out.
  • Needle clip in mid position.
  • Turn air screw all the way in then 1/4 turn out.
  • Adjust idle so the bike will just barely idle.
PILOT JET CORRECT:  With one hand on the throttle maintaining RPM at approximately 1/8 throttle, turn air screw 1/4 turn at a time clock wise until you bottom it out. Motor should become slightly erratic and you should have to play with throttle to maintain RPM. Start turning air screw counter clock wise, 1/4 turn at a time until you have reached 2 3/4 turns out. Between 1 1/4 and 2 1/4 turns, your motor should have reached its highest RPM maintaining a steady throttle. Adjust air screw again between 1 1/4 and 2 1/4 until you have determined highest RPM. Quick throttle response should be clean without bog.
PILOT JET TO RICH:
RPM does not reach a peak between 1 1/4 and 2 1/4 turns, stays the same or keeps rising out to 2 3/4 turns.
Correction: Mikuni replace pilot jet with next leaner and test again. Keihin replace pilot jet with next leaner and test again.
PILOT JET TO LEAN:
RPM does not become erratic and motor maintains throttle when air screw is turned all the way clockwise.
Correction: Mikuni replace pilot jet with next richer and test again. Keihin replace pilot jet with next richer and test again. Remember, with a steady throttle approximately 1/8, there should be a distinct difference in RPM from 1 1/4 turns to 2 1/4 turns if the pilot jet is correct. The emphasis here is to find a pilot jet that will run crisp without bog and without the main jet.
Jetting data base
« Reply #16 on: July 15, 2013, 11:56:56 AM »
[h=3]Step 3: DETERMINE THE CORRECT MAIN JET.[/h]The main jet selection process is easy once you have the correct needle diameter or needle jet. You now only have to correct a rich condition from 3/4 throttle on up and you know what a rich condition sounds like. Your pilot circuit is correct and without bog.
  • Replace main jet with one that is at least two sizes smaller.
By replacing the main jet with one that is too small, you are looking for a condition that is too lean. You adjust your main jet from a too small to lean condition.
Condition: Motor running and main jet in.
MAIN JET CORRECT:
Carburetor should run clean and crisp to full throttle.
MAIN JET TOO RICH:
RPM reaches a peak slowly with a deep sound. Excess fuel and oil mixture at end of silencer. Spark plug fowls easily and is dark in color.
Correction: Mikuni replace main jet with next leaner and test again. Keihin replace main jet with next leaner and test again.
MAIN JET TOO LEAN:
RPM reaches a peak quickly but erratic. A quick full snap open of throttle causes the motor to hesitate BEWAH sound or a complete bog. Motor sounds like it has a ring to it. End of silencer white. Spark plug is white in color.
Correction: Mikuni replace main jet with next richer until the BEWAH bog just barely goes away, then replace the main jet with the next richer and run it. Keihin replace main jet with next richer until the BEWAH bog just barely goes away, then replace the main jet with the next richer and run it. The emphasis here is find a main jet that is just rich enough to allow you snap the throttle wide open without the motor bogging as a result of the main being too lean. Should be a quick crisp throttle with no hesitation.
[h=3]Step 4: DETERMINE THE CORRECT NEEDLE TAPER AND CUT AWAY.[/h]This step in the jetting process can be made very simple if you remain close to stock. However, your needle taper is adjusted for 1/2 throttle to 3/4 throttle. Start off with a rich taper (shallow taper angle) and keep going leaner (steeper taper angle) until it will not maintain constant RPM at 1/2 throttle (runs erratic). Go back to the leanest taper angle that ran the smoothest at 1/2 to 3/4 throttle and that should be the correct taper.
The needle taper final test should be under track conditions with the greatest effect entering and exiting corners. Do not change the needle diameter or needle jet size during this process because that has already been determined. Adjust taper and throttle cut away only.
Throttle cut away effects from idle to 1/4 throttle. The correct cut away will maintain steady 1/8 throttle with quick throttle response. Generally the stock cut away is very close. Experiment with different cut away until it maintains the best response to 1/4 throttle.
That's it, if you spend the time jetting correctly, the benefits you will gain definitely out-weigh way the time spent. Take the guesswork out jetting by following a procedure that has been given or one you have laid out yourself. Keep the black magic process out of your tuning tricks and you will be better off for it.
From an article by Don K. Courtney. Link is dead now.
Jetting data base
« Reply #17 on: July 15, 2013, 11:57:42 AM »
[h=3]Jetting Tip: pilot jet and air screw[/h]To check to see if your pilot jet and air screw are adjusted right, warm up the motor and let it idle as low as possible while still running smooth. From idle, whack the throttle wide open then let it close completely. Listen to the motor. If it bogs right when you whack the throttle open, then revs up, turn the air screw in 1/2 turn then try again. Do this until it revs up crisply. After the motor revs up, listen to it revving back down. If the revs drop quickly, and the motor starts to bog, and/or die, then you're too rich on the air screw, back it out 1/4 turn at a time. If after you let the throttle off the motor tends to run on and on while revving down very slowly, you're too lean and need to turn the air screw in 1/4 turn at a time. You want the revs to come up from idle quickly and smoothly, then drop back down to idle the same way. If you turn the air screw all the way in and it still needs to go further, then you will need a larger pilot jet. The opposite is also true: if you are backing the screw out so far that it darn near falls out, you will need a smaller pilot jet.
[/HR][h=3]Needles[/h]The three letters refer to different aspects of the needle. In turn you have:
  • Taper: most effective at ½-¾ throttle.
  • Length/clip position: most effective at ¼-½ throttle.
  • Diameter: most effective towards ¼ throttle.
Higher taper letters are richer; for diameter and length, higher letters are leaner.
For example, going off a standard JJH needle (our old N80F needle was close), and comparing with our other needles:
  • GJH: leaner taper, so leaner at ½-¾ throttle.
  • LJH: richer taper, so richer at ½-¾ throttle.
  • JJK: leaner diameter, so leaner towards ¼ throttle.
  • JJF: richer diameter, so richer towards ¼ throttle.
[TABLE=class: t-sm]
[TR]
[TH=colspan: 3][/TH]
[TH=colspan: 13]Diameter              [/TH]
[/TR]
[TR=bgcolor: #d7d7d7]
[TH]Taper (A)
in degrees[/TH]
[TH](L1) Length
in mm[/TH]
[TH][/TH]
[TH]D=
2.405[/TH]
[TH]E=
2.405[/TH]
[TH]F=
2.415[/TH]
[TH]G=
2.425[/TH]
[TH]H=
2.435[/TH]
[TH]J=
2.445[/TH]
[TH]K=
2.455[/TH]
[TH]L=
2.465[/TH]
[TH]M=
2.475[/TH]
[TH]N=
2.485[/TH]
[TH]P=
2.495[/TH]
[TH]Q=
2.505[/TH]
[TH]S=
2.525[/TH]
[/TR]
[TR]
[TH]G
2° 26'[/TH]
[TH]F=22.25[/TH]
[TH]Rich[/TH]
[TH=colspan: 4][/TH]
[TH]GFH[/TH]
[TH][/TH]
[TH]GFK[/TH]
[TH=colspan: 6][/TH]
[/TR]
[TR]
[TH]J=25.40[/TH]
[TH]Lean[/TH]
[TH]GJH[/TH]
[TH]GJK[/TH]
[/TR]
[TR]
[TH=colspan: 16]
[/HR][/TH]
[/TR]
[TR]
[TH]H
2° 45'[/TH]
[TH]F=22.25[/TH]
[TH]Rich[/TH]
[TH=colspan: 2][/TH]
[TH]HFF[/TH]
[TH]HFG[/TH]
[TH]HFH[/TH]
[TH][/TH]
[TH]HFK[/TH]
[TH][/TH]
[TH=colspan: 5][/TH]
[/TR]
[TR]
[TH]K=25.85[/TH]
[TH][/TH]
[TH]HKF[/TH]
[TH]HKG[/TH]
[TH]HKH[/TH]
[TH]HKJ[/TH]
[TH]HKK[/TH]
[TH]HKL[/TH]
[/TR]
[TR]
[TH]L=27.20[/TH]
[TH]Lean[/TH]
[TH][/TH]
[TH]HLG[/TH]
[TH]HLH[/TH]
[TH]HLJ[/TH]
[/TR]
[TR]
[TH=colspan: 16]
[/HR][/TH]
[/TR]
[TR]
[TH]J
3° 00'[/TH]
[TH]F=22.25[/TH]
[TH]Rich[/TH]
[TH]JFG[/TH]
[TH][/TH]
[TH]JFJ[/TH]
[TH][/TH]
[TH]JFL[/TH]
[TH][/TH]
[TH]JFN[/TH]
[TH]JFP[/TH]
[TH]JFQ[/TH]
[TH]JFS[/TH]
[/TR]
[TR]
[TH]G=23.60[/TH]
[TH=colspan: 10][/TH]
[TH]JGN[/TH]
[TH][/TH]
[TH]JGQ[/TH]
[TH]JGS[/TH]
[/TR]
[TR]
[TH]J=25.40[/TH]
[TH][/TH]
[TH]JJD[/TH]
[TH]JJE[/TH]
[TH]JJF[/TH]
[TH]JJG[/TH]
[TH]JJH[/TH]
[TH]JJJ[/TH]
[TH]JJK[/TH]
[TH]JJL[/TH]
[TH]JJM[/TH]
[TH]JJN[/TH]
[TH]JJQ[/TH]
[TH]JJS[/TH]
[/TR]
[TR]
[TH]L=27.20[/TH]
[TH]Lean[/TH]
[TH]JLF[/TH]
[TH]JLG[/TH]
[TH]JLH[/TH]
[TH]JLJ[/TH]
[/TR]
[TR]
[TH=colspan: 16]
[/HR][/TH]
[/TR]
[TR]
[TH]K
3° 15'[/TH]
[TH]L=27.20[/TH]
[TH]KLF[/TH]
[TH]KLG[/TH]
[TH]KLH[/TH]
[TH]KLJ[/TH]
[TH]KLK[/TH]
[/TR]
[TR]
[TH=colspan: 16]
[/HR][/TH]
[/TR]
[TR]
[TH]L
3° 33'[/TH]
[TH]G=23.60[/TH]
[TH]Rich[/TH]
[TH]LGG[/TH]
[TH]LGH[/TH]
[TH]LGJ[/TH]
[TH][/TH]
[TH]LGL[/TH]
[TH][/TH]
[TH]LGN[/TH]
[TH][/TH]
[TH]LGQ[/TH]
[TH]LGS[/TH]
[/TR]
[TR]
[TH]J=25.40[/TH]
[TH]Lean[/TH]
[TH]LJG[/TH]
[TH]LJH[/TH]
[TH]LJJ[/TH]
[/TR]
[TR]
[TH=colspan: 16]
[/HR][/TH]
[/TR]
[TR]
[TH]M
3° 50'[/TH]
[TH]J=25.40[/TH]
[TH]Rich[/TH]
[TH=colspan: 9][/TH]
[TH]MJN[/TH]
[TH][/TH]
[TH]MJQ[/TH]
[TH]MJS[/TH]
[/TR]
[TR]
[TH]L=27.20[/TH]
[TH]Lean[/TH]
[TH=colspan: 7][/TH]
[TH]MLL[/TH]
[TH][/TH]
[TH]MLN[/TH]
[TH]MLQ[/TH]
[TH]MLS[/TH]
[/TR]
[/TABLE]
Jetting data base
« Reply #18 on: August 02, 2013, 10:11:25 AM »
My old stock cyl setup
Mixture ratio and fuel: 32:1 vp c12 HP2 oil
Carb Type/size:38 pwk as
Main Jet size: 168-170
Slow (pilot) Jet size:50
AirScrew (number of turns out): 1.5
Needle (what groove is the clip in, Brand, etc): DGL
Reed brand and type: Boyesen Rad valve fiberglass reeds
Airbox/filter/eliminator: 06' 450r Venon eliminator w/ Uni filter
Pipe: Sparks MX
Engine Displacement: 265cc oem cyl
Compression ratio: 230 psi with 19cc dome
Porting type: Jerry Hall mx porting
Altitude: 600-700ft above sea level
Cr250 ignition,Br8es at .22 gap
Jetting data base
« Reply #19 on: August 02, 2013, 10:16:49 AM »
New setup,Baldwin ported pro-x 265pv
Mixture ratio and fuel: 32:1 vp c12 Hp2 oil
Carb Type/size: 38pwk as
Main Jet size: 182
Slow (pilot) Jet size:52
AirScrew (number of turns out):1.5
Needle (what groove is the clip in, Brand, etc): Dgl middle groove
Reed brand and type:Cr250 intake and cage,spacer,fiberglass reeds
Airbox/filter/eliminator: JL eliminator,86 boot,Uni filter
Pipe: Sparks TT,Dg silencer
Compression ratio:240psi
Porting type: Baldwin ported Mx
Altitude: 600-700 ft above sea level
01' Cr250 ignition,br8es,.22 gap
« Last Edit: August 09, 2013, 09:42:13 AM by 05450r »
Jetting data base
« Reply #20 on: January 24, 2014, 12:46:50 AM »
Bump, need more people to build this up!
Jetting data base
« Reply #21 on: January 24, 2014, 10:43:53 AM »
Pro-X 310 (300) Dune Port
Mixture ratio and fuel: 32:1, VP C12 or similiar, Klotz R50
Carb Type/size: Keihin 38 PWK/AS
Main Jet size: 195
Slow (pilot) Jet size: 55
Air Screw (number of turns out): 2
Idle Screw(number of turns out): 1.25
Needle (what groove is the clip in, Brand, etc): Not sure
Reed brand and type: Boyseen Rad
Airbox/filter/eliminator: Stock boot, open K&N with Outerwears
Pipe: Curtis Sparks TT
Engine Displacement: 297
Compression ratio: 235psi
Porting type: Dune port from Dave Moore Racing
Altitude: Sea Level
Jetting data base
« Reply #22 on: January 24, 2014, 10:52:29 AM »
ESR 310PV with TRX 9 Port
    Mixture ratio and fuel: 50:1, Benton Oil 110 race fuel, Amsoil Dominator
    Main Jet size: 172-175
    Slow (pilot) Jet size: 50
    Idle Screw(number of turns out): 1.5
    Needle (what groove is the clip in, Brand, etc): DGH 3rd clip
    Reed brand and type: Delta Force 3
    Airbox/filter/eliminator: Stock box, with airbox outerwear in place of lid, UNI filter
    Pipe: Curtis Sparks MX
    Engine Displacement: 293cc? stock bore
    Compression ratio: 205psi
    Porting type: ESR TRX 9
    Altitude:  675 feet above sea level
    Ignition: CR250 ignition w/ B8es
Offline mwiley
Jetting data base
« Reply #23 on: March 19, 2014, 11:36:53 AM »
Mix= 32:1 amsoil/112 Dragon
Carb= 38mm Air stryker
Pipe= LRD Adjustable with FMF quiet core silencer
Air box= Unifilter with slots milled in airbox lid
Reeds= Boyseen Rad valve
Bore= 67.25/255cc
UCCR= 14.85/1
Compression= 230psi
Porting= Sometype (not sure what rpm range)
Altitude= 850ft
Main jet= 178
Slow jet= 50
Air screw= 2 turns out
Needle= CEJ with clip in 3rd position
Temp= 65 degrees
Spark plug= BR8ES gapped at .022
Offline atvmxr
Re: Jetting data base
« Reply #24 on: September 17, 2019, 08:54:39 AM »
Mixture ratio and fuel:  927 with 50/50 Sunoco 110 and 93 pump
Carb Type/size:  38A/S
Main Jet size: 172
Slow (pilot) Jet size: 52
Needle (what groove is the clip in, Brand, etc): 4th groove DGH.  3rd clip was too lean
Reed brand and type: Boyesen Rad Valve
Airbox/filter/eliminator: Uni 2 stage filter, stock box, no lid, no toil oil
Pipe: ESR TRX6
Engine Displacement:  0.080 over stock cylinder, 21cc dome cool head, long rod crank, spacer plate, 86 wiseco piston
Compression ratio: unk
Porting type: unk, mid range
Altitude: sea level
