Author Topic: Huge parts Post little bit of everything  (Read 28121 times)
Offline motofool250r
« on: October 22, 2016, 10:13:59 PM »
My Paypal is WilliamBrosam@gmail.com Please remember to add 3% for the fees or send as Gift. shipping is not included in any prices Listed.
 Stock radiator 20
jp stem SOld
8x8 Drag Cut Superlite Wheels  100$
Chrome Tie Rods 50$
« Last Edit: October 30, 2016, 07:08:03 PM by motofool250r »
Hybrid Stable
443cc LSR/Roll/Stellar Duner
363cc Backup Duner
In progress JP no-link Duner
Next bike now loading.....
« Reply #1 on: October 22, 2016, 10:14:31 PM »
20$ each no tears or problems with any
 ESR Clutch Cover Sold
PWK 40.5mm Bored Carb  100$
Anti Fade Brake Hub SOLD
Brake Stay 15
CR250 Ignition Plate custom free with any other Purchase
Polished AIrbox Eliminator 75
Unpolished Version SOLD
Chrome Big Bore Reed Boot 30
Regular Reed cage Boots 15
5$ each for Blue/Black Cylinder hose
ESR Silencer Regular Mount  75$
CSFX SOLD
Laeger Swingarm SOLD
Two Cool Heads one for stock Cylinder and one for 330cc ProX Cylinder  50 for each
« Last Edit: November 12, 2016, 10:02:00 PM by motofool250r »
Hybrid Stable
363cc Backup Duner
« Reply #2 on: October 22, 2016, 10:15:24 PM »
V force3 Reeds Bolted on and removed SOLD
PEP 88-89 Rear canister Clamp SOLD
ESR Center pipe Mount 20$ SOLD
Works Resi Front Clamps Round Frame 25$ (pair)
Works Front Resi Clamp for Square Frame 25$ (pair)
Round Clamp For Brake Line on rear Swinger 15
Lonestar Rear Hubs SOLD
Spacer to use 86-87 Swingarm on 89 Frame  25$
Anti Vibe Bar clamp for Std handle bar Size 40$
Stock Size Fuel Tank and Polished Fuel Cap SOLD
86-87 Front Hubs 20$ nice Fresh Blue Translucent 2 stage Powder
Factory Head Stay SOLD, Front Motor Mounts, and Brake Hub Stay $5 Each
2 rear Brake Levers one Longer translucent Purple Powder never used, one shorter Black  10 Each
Rear Suspension Link Bearings Seem to be good, one part is Blue one is Purple  30$ each
Dont remember the make nacs or hardkor have bearings and spacer just need to locate them. 75$
Shearer Stock size silencer 25$
Chrome Stock Kicker 50
Stock Thumb Throttle SOLD
Stock trx20r Flywheel Cut down for lightest weight possible 15$ (work done my MP Racing Dave moore)
« Last Edit: November 13, 2016, 12:55:04 PM by motofool250r »
Hybrid Stable
363cc Backup Duner
« Reply #3 on: October 22, 2016, 10:15:54 PM »
Chrome Clutch Lever Arm, and Spring
89 Style Brake Rotors good condition not warped. 25$
Tusk Blue anodized Gas Cap 25 $
Works Resi Clamp for Square stock Style Frame 15$
Brake Resi COver and Screws 5$
Tm Design Chain SLider As New SOLD
Moose Frame Protector 10$ SOLD
Cylinder Spacer Plate approximately 4mm Thick if you need sae measurement i can Mic it.
Front Sprockets 15, 13, 10$ each 14 SOLD
12, 13 x 2, 10$ 14 tooth SOLD
Aluminum 38 20$, 36 tooth SOLD
44mm Lectron Billet Bowl, 2 PowerJets 175$
42mm Keihin Carb  100$
Boyssen Rad Valve SOLD
86-87 Grab Bar SOLD
86-87 Motor Mount SOLD
JP Frame/Early LSR Pegs SOLD
Tm Design Front Seat Mount SOLD
Fresh Chromed Brake Lever SOLD
Stock Axle Locknut 25$
Anti fade brake hub/lock Nut 100
85 ATV Brake Lever and Spring 15
HEP Stock peg kick ups and sharp teeth to add to oem pegs. 20$
Oversized gas tank i think its a 3.6 Gallon 75$
« Last Edit: November 13, 2016, 03:18:54 PM by motofool250r »
Hybrid Stable
363cc Backup Duner
« Reply #4 on: October 22, 2016, 10:16:25 PM »
Front Bumper SOLD
86-87 Seat latch 25$
Skat Trak Clutch Hub 75$
1 polished Motor Mount 10$
JT Sprocket SOLD
Tm Design Front Seat Mounts 25$
Cool head Dome 20$
Pro Design SHifter 30$
Stock Clutch arm and Spring 25$
86-87 Stock Motor Mount SOLD
Inner CLutch Hub Sold
Stock Shock COvers 5$
« Last Edit: November 12, 2016, 10:29:36 AM by motofool250r »
Hybrid Stable
363cc Backup Duner
« Reply #5 on: October 22, 2016, 11:32:33 PM »
89 Style Seat with Cascade Seat Cover 125$
86-87 Style Seat with Desert Seat SOLD
87 style stock ignition working when pulled. 70$
88 or 89 CDI Box 40$
trx250r front brake and stainless lines 80$
400ex front calipers need to be rebuilt 25$ Comes with rebuild Kits
trx250r rear brake caliper good condition SOLD
Stock Tierods ends usable 30$ for both
Wider Tierods 25$ ends are usable
88 hubs and spindles(not tapered) and rotors 25$
LSR Carrier damage is from when my Puma Broke the LSR sprocket hub and chain and sprocket chewed up the carrier as i tried to stop. 30$
« Last Edit: November 12, 2016, 10:30:55 AM by motofool250r »
Hybrid Stable
363cc Backup Duner
« Reply #6 on: October 22, 2016, 11:33:06 PM »
saved for even more
Blasted Top Left 25$
Polished Bottom Left 50$
Black Top Right 35$
Bottom Right 20$
Blasted one on Left 40 One on RIght 50$
Both Have Water Pump Shafts Black 50
Polsihed 75$
45$ each
« Last Edit: November 12, 2016, 10:31:39 AM by motofool250r »
Hybrid Stable
363cc Backup Duner
« Reply #7 on: October 22, 2016, 11:33:43 PM »
Stock Shocks 30$ each
Long Travel Works with Resi and Comp adjust need some TLC 150$$
400ex thumb Throttle with cable (top left)40$
250r with Billet cover and throttle cable (Bottom Left)
2 spare throttle cables one 15$, one 10$
PJ carb 34mm 50$
2 rear seat  brackets 20$ each
1 chrome rear seat latch 25$
OEM reed cage with good carbon Reeds 20$
OEM Shifter 15$
Rear Shock Linkage, sanded down ready for finish polish 20
Rear shock linkage with bolts 25$ slight tweak in wish bone.
OEm Clutch cable with Stator Mounted cable stay 20$pending dp250R
OEM CLutch cable no stay 10$
Stock Kicker with perfect condition Knuckle no slop 75$
Stock Kicker with good Knuckle 40$
Custom Axis Shock SOLD
Chains 520 DID non-Oring on top 100 link New Never Used 20
Primary Drive on Bottom SOLD
« Last Edit: November 13, 2016, 03:02:44 PM by motofool250r »
Hybrid Stable
363cc Backup Duner
« Reply #8 on: October 23, 2016, 04:21:23 AM »
I need a junk Keihin carb to robtain parts off of. PE, PJ, PWK?
Best regards
-Jason
« Reply #9 on: October 23, 2016, 09:50:07 AM »
ill keep looking so far all ive found is 40.5's or 42mm bored out ones.
Hybrid Stable
363cc Backup Duner
« Reply #10 on: October 23, 2016, 10:50:04 AM »
Quote from: motofool250r;70318
Stock Stator Cover 20
stock clutch cover 40$
 40$ Chrome 86-87 Grab Bar
Chrome Tie Rods 50$
I would like to get these Will
« Reply #11 on: October 23, 2016, 10:52:39 AM »
I'll take the TM front seat mounts, paypal please
« Reply #12 on: October 23, 2016, 11:42:15 AM »
I want the anti fade
« Reply #13 on: October 23, 2016, 11:53:58 AM »
i Have 1.5 Sets left (meaning i have 3 cause one got destroyed or Lost.) paypal is now at the top in First Post, Williambrosam@gmail.com
Hybrid Stable
363cc Backup Duner
« Reply #14 on: October 23, 2016, 11:54:30 AM »
Which one there is Two,
Hybrid Stable
363cc Backup Duner
