Author Topic: Seal surface fix for aluminum hub.  (Read 3669 times)
« on: November 03, 2016, 09:06:05 PM »
Picked up a lone star axle. The seal surface on the sprocket hub was grooved. So decided to see if I could fix it. This is what I started with.
This is the speedi sleeve from Napa I used.
This is the end result.
The sleeve has a flange on it for install. Had to remove the flange to get it on the last little bit. Hope this might help someone.
« Reply #1 on: November 03, 2016, 11:25:00 PM »
Yup thats one way or ya can put in a lathe an cut it down an use the replacement sleeve rpm sells . Its alot thicker then a speedi sleeve
« Reply #2 on: November 03, 2016, 11:34:43 PM »
Just figured I would give it a shot. I did not want to take it to a lathe. Just an option for people.
« Reply #3 on: November 04, 2016, 12:16:26 AM »
Third option would be build it up with weld and re turn the piece as well.
« Reply #4 on: November 04, 2016, 12:31:27 AM »
Only problem with that is you are still using the soft aluminum for sealing surface
« Reply #5 on: November 04, 2016, 12:37:48 AM »
The aluminum would be even softer after welding
