Author Topic: Tow Rigs  (Read 21073 times)
Offline desertR
Re: Tow Rigs
« Reply #30 on: March 04, 2020, 06:34:59 PM »
While the compressor is nice, I have air bags on two of my current rigs and one past rig, and they only need air added maybe twice a year, even though I check them every trip. As long as they don't leak they are fine. The volume is so small, I carried a bicycle pump to top up the bags if needed.
desertR
Re: Tow Rigs
« Reply #31 on: March 04, 2020, 06:56:01 PM »
I inflate and deflate my bags evey every time I tow something.  My 5th wheel has 3500lb of pin weight. So I add 40psi after I hook up to the trailer. No way would I drive my truck around with 20psi in the bags. It would knock your teeth out every time you hit a bump lol
Re: Tow Rigs
« Reply #32 on: March 04, 2020, 09:37:25 PM »
Thanks guys. I pull that trailer maybe 6 times a year (wish it was more).  There’s so much sag in the suspension that it just looks so squatted in the rear.  Minus the headlights pointed up, it pulls and drives great, never really even feel it bottom out.  So haven’t pulled the trigger on anything.
Offline desertR
Re: Tow Rigs
« Reply #33 on: March 04, 2020, 10:01:49 PM »
Ya, My camper is probably only 1200lbs. but the springs on my truck (63" springs Chevrolet C 1500) are so soft that I get vibrations from the rear axle tipping unless I run 30/40lbs. in the bags. It probably has to do with the quality of Washington hi ways also, they really suck. Our Hi ways are so bad that Kenworth has a computer program to simulate the I-5 areas between Olympia and Marysville as part of their quality control used when they design their trucks.
desertR
Offline Rooster
Re: Tow Rigs
« Reply #34 on: March 08, 2020, 07:39:10 AM »
My workhorse.
« Last Edit: March 08, 2020, 07:14:17 PM by Rooster »
Re: Tow Rigs
« Reply #35 on: March 11, 2020, 10:21:21 AM »
Deleted makes all the difference
It sure does. I've driven a few non-tuned 4th gens and they don't compare.
Only bad thing about mine is I don't have a clue what tune is in it. The tuner didn't come with it. I'd really like to figure out if I have a trans tune, as this has a 68RFE trans that operates just fine right now. It seems to shift similar to my buddy's identical truck, which doesn't have one.
Offline 2Nubs
Re: Tow Rigs
« Reply #36 on: March 11, 2020, 12:30:17 PM »
68’s are great as long as you don’t have the bug to make big power. 48re swap is the way to go for that.
‘86 330
Re: Tow Rigs
« Reply #37 on: March 11, 2020, 03:25:45 PM »
This is what I've been reading as well. I have zero plans to make anything over stock power. I just want it fully deleted, which it is.
I've read that a good trans tune will really help the longevity of the 68, just have to figure out if I have a trans tune in mine or not lol.
Offline 2Nubs
Re: Tow Rigs
« Reply #38 on: March 11, 2020, 03:40:52 PM »
You got it Tbone. Great towing and dd Trans. Good tune to up the line pressure will help it live a long life.
‘86 330
