Author Topic: Outlaw banshee  (Read 20094 times)
Offline lrd_250r
Outlaw banshee
« on: January 11, 2017, 04:24:34 PM »
New project for the remainder of winter, outlaw banshee with a 250r rear link instead of a no-link. I will post as I go.
Sent from my SM-G900V using Tapatalk
Outlaw banshee
« Reply #1 on: January 12, 2017, 11:20:30 AM »
I almost bought this off Dan hung.  I got a yfz450 banshee nearly complete so I had to pass.  This will be a cool build.  Any plans on engine and suspension?
Offline lrd_250r
Outlaw banshee
« Reply #2 on: January 12, 2017, 05:52:34 PM »
Most likely PEP Pb1's. I have a stock motor to start with, not sure what to do with it. I'm in the desert alot, what would you do in terms of a motor?
Outlaw banshee
« Reply #3 on: January 12, 2017, 09:29:42 PM »
Quote from: lrd_250r;71390
Might look into a Serval cylinder setup. Might also ask [MENTION=1053]JohnTabata1[/MENTION]
Offline lrd_250r
Outlaw banshee
« Reply #4 on: January 12, 2017, 09:58:36 PM »
Ok I definitely will
Outlaw banshee
« Reply #5 on: January 12, 2017, 11:44:05 PM »
Strange front shock mounts. Is that an lsr frame?
Offline lrd_250r
Outlaw banshee
« Reply #6 on: January 13, 2017, 07:40:41 AM »
Yep, LSR outlaw banshee frame, most of the ones I have seen are a no-link swingarm, this one uses the 250r rear suspension linkage
Offline lrd_250r
Outlaw banshee
« Reply #7 on: January 13, 2017, 07:41:20 AM »
Requires 20" front shocks
Outlaw banshee
« Reply #8 on: January 13, 2017, 06:39:33 PM »
Send that engine to Jerry hall.
Offline lrd_250r
Outlaw banshee
« Reply #9 on: January 13, 2017, 07:33:54 PM »
What's the best way to reach jerry hall?
Offline lrd_250r
Outlaw banshee
« Reply #10 on: January 13, 2017, 07:34:28 PM »
Offline lrd_250r
Outlaw banshee
« Reply #11 on: January 13, 2017, 07:34:58 PM »
Starting the rearend tonight
Outlaw banshee
« Reply #12 on: January 15, 2017, 07:54:32 AM »
PM jerry.  He is active on the site
Offline ytman
Outlaw banshee
« Reply #13 on: January 15, 2017, 09:34:37 AM »
I've only raced a couple of Banshees. Stock power was plenty for me. Getting the power down low was key. That and an easy clutch pull. When the going got tight I had to use the clutch ALOT. Otherwise I was just roastin' tires. They already have long legs on top. That bike you're building should be a blast.
Offline lrd_250r
Outlaw banshee
« Reply #14 on: January 15, 2017, 09:59:25 AM »
Ytman thanks for the info, what can I do for that hard clutch pull?
The build is going good but I have to say the front fenders are a fitting nightmare. This shocks me, first LSR build where I had fitment issues.
Also.does anyone know the easiest way to remove the front upper case dampers?
