Author Topic: 1988 trx250r  (Read 5965 times)
Offline bcm
1988 trx250r
« on: February 15, 2017, 02:51:51 PM »
I got a 1988 Honda trx 250r with a built esr motor esr 330 cylinder kit with esr head and a 4 mil stroker crank esr trx-11 center mount pipe kit with silencer over sized keihin carb from esr with esr air box removal kit esr temperature gage and esr water pump esr reeds and spacer and esr case saver , pumashine engine dress up kit, pumashine engine mounts and pumashine seat mount, fireball racing +6 inch swingarm and stock swingarm, adjustable rear axle, a 38 and 36 rear sprocket and front 13 and 14 sprocket with brand new gold 520 did chain, esr brake block off with wave brake disc and esr resevor mount, ims pegs shifter and brake lever, skat trak triple buff front sand tires and skat trak 10 paddle triple buff rears on Douglas blue label wheels, tag over size bars with mount. Fresh gear oil plug air filter and pre filter and 5gallons of 110 and bring your own gas can and have 2 gallons of 110 already premixed
Pink slip in hand and green sticker is good until June 2017
Great 250r runs amazing very, located in Rocklin California
$3000
« Last Edit: February 15, 2017, 03:55:42 PM by bcm »
