Author Topic: Used good condition 400ex tie rods inner and outer. Trade for a good working Petcock  (Read 4379 times)
Offline DeathPunch88_250R
Looking for a good working coedition petcock. My R won't hardly run on reserve. Replaced fuel lines and found petcock leaking.
If you need anymore pics in can post them up.
Quote from: DeathPunch88_250R;72003
If your internals aren't physically worn beyond repair you can get new seals for the petcock & rebuild it for less than you'll probably find a used possibly leaky one. However the issue could be in the reserve portion of the fuel strainer in your tank.
Kevin how do I check the strainer?
Pull fuel line an check flow. You can blow some air in fuel line  [not 200psi lol ] an recheck flow. I like to spray some brake / carb cleaner in line then a lil blast of air. If mixed fuel was sitting in tank for long time the cleaner will help break it down. Also loosen fuel cap while doing this .an you can also check your vent tube if is pinched or clogged with dirt or whatever it will not let the fuel flow correctly
Cool info Thanks man
get a Pingel petcock.
John
