Author Topic: K&S bearings and seals,any feedback?  (Read 9479 times)
« on: July 04, 2013, 02:34:18 PM »
So I had some discounts to use from Boss Bearing,from a previous build. So I decided to order their complete engine bearing,seal and gasket kit made by K&S. Will also be ordering their wheel bearing and swingarm kit since I got more discounts from the engine kit. Has anyone used the engine kit,I will be getting oem crank bearings and seals but how about the rest of the kit?
« Reply #1 on: July 04, 2013, 02:37:58 PM »
I used them on a stock engine rebuild I did about 5yrs ago. I used the crank bearings and seals and never had a problem.
« Reply #2 on: July 04, 2013, 02:40:20 PM »
I am a firm believer in OEM crank seals and OEM 8 ball crank bearings.
« Reply #3 on: July 04, 2013, 02:56:46 PM »
Quote from: etccb;401
I agree,this will mainly be a TT motor,265pv,it will be pulling some consistant upper rpm's at times.
« Reply #4 on: July 04, 2013, 02:59:46 PM »
I used the K&S gasket set once and I will only use OEM or Cometic now. Lets us know what you think of the gaskets.
« Reply #5 on: July 04, 2013, 03:02:05 PM »
Will do,motor going back together next week,waiting on powder coater for frame,etc.
Offline derby
« Reply #6 on: July 04, 2013, 04:03:21 PM »
I have used K&S kits before.  But I don't use the crank seals or bearings I only use oem there.  The rest of the bearings and seals from k&s have been good quality.  I have not put 20 years on them like oem so time will tell.
« Reply #7 on: July 11, 2013, 10:17:57 PM »
Got the kit in today,start assembly tomorrow if the kids allow me some free time,lol! Everything looks good,crank bearings are 8 ball design. Im going to use those and the crank seals,so I will be a test mule for this. Bearings going on a new Hot Rod crank as well. I will take notes and some pics to use in by build thread.
Offline mennis1971
« Reply #8 on: July 13, 2013, 10:27:55 AM »
I've used them a couple of times with no problems. Just remember to grease the lips of the seals(especially the mains).
« Reply #9 on: July 13, 2013, 11:19:32 AM »
Good,thank you Mennis! Yep,always lube the seals! I should get started on this today,mainly getting stuff cleaned up and laid out on the bench. Got my stainless bolt kit in yesterday. I have almost 10hrs (not straight hrs) cleaning,stripping and repainting my cases,so atleast that parts done
« Reply #10 on: July 17, 2013, 12:12:40 PM »
Got the bearings in the cases,no issues. Left them in the freezer for 3 days,while the cases sat in the hot garage. Drove them in with minimal effort,all good so far!
« Reply #11 on: July 17, 2013, 12:32:59 PM »
i accidentally used a k&s when bolting on a cylinder and at one point spilled gas or something on the cylinder it leaked down and sort-of dissolved the gasket.lol
« Reply #12 on: July 17, 2013, 12:48:26 PM »
Lol,well hopefully that dont happen! Still waiting on another base gasket(spacer plate) and a couple reed gaskets for the spacer and cr250 cage setup.
« Reply #13 on: July 19, 2013, 02:35:07 PM »
Update,and Im taking this as a sign from the 250r gods. Got tranny built and installed,triple checked everything. Go to open the package for the gaskets,being careful I slowly peal the plastic away from the cardboard and of course,the center case gasket and stator cover gasket stick and immediately tore. UGH!!.. Call Boss Bearing,they say send the whole kit back and they will ship a new one. She tried telling me I had to take my bearings back out,yeah right!!... After talking to her supervisor I just had to email pictures of the gaskets and they will issue a refund and Im supposed to repurchase the kit. Yeah right!!
« Reply #14 on: July 19, 2013, 03:23:01 PM »
That blows man, I may have a center gasket. Let me check when I get home from work and I'll just ship it to ya. How bad did it tear up the stator gasket, you may be able to run it till the new one comes.
