Author Topic: conversion motor cycle lift to atv lift  (Read 5591 times)
Offline DOUGLAS
« on: July 16, 2017, 09:36:57 PM »
bought this lift last year. i finally finished most of my work on my shop / basement. i got the harbor freight motor cycle lift for $ 299 on sale with the intention of converting it into an atv lift. decided to use stainless for the platform and ramps. drilled through the frame of the lift added 3 peices of 1 x 48 inch inch solid steel to support platform. these are not welded into the frame they are bolted into the sides of the stainless platform with 1/2 inch by 1 inch bolts. on the top side i used 1/4 20 nuts and bolts. about 10 per side. i also had the fabrication shop put slots in the pieces just for added effect. i modified the foot pedal by extending it then added a block under as a leverage point. it works awesome. i was searching around for an atv lift and i decided to try this approch. don't be fooled the conversion was almost as much as just buying an atv lift. i had the parts made then i did the labor to build it. i also cut off 11 inches 1 inch in the front and 10 inches in the back. this is so i can stand it up to clear the floor joists when not in use. i have a low ceiling height the bottom of the joist is 77 inches. the lenght of the lift is now 76 inches. this will keep my floor space clear. i am hoping to install a small harbor freight winch up into the raftes to lift it up and down instead of doing it manualy.
« Last Edit: July 16, 2017, 09:40:06 PM by DOUGLAS »
LED 363 87 stock frame
Re: conversion motor cycle lift to atv lift
« Reply #1 on: July 19, 2017, 08:36:02 PM »
Looks good Doug
« Reply #2 on: July 19, 2017, 09:57:32 PM »
Nice idea!
« Reply #3 on: July 19, 2017, 10:08:03 PM »
Nice job! I also bought this lift for $300 with a coupon. Well worth the money imo.
Offline Phoenix843
« Reply #4 on: July 19, 2017, 10:28:22 PM »
Cool project and mods to make it work as you intended. I would like to do something like this for my garage in near future but first things first.....wood burner for winter out there. I'm sick of freezing in January/February out there working on my projects.
Offline huntertools
« Reply #5 on: July 19, 2017, 11:09:46 PM »
Looks good. Shop looks nice also.
Offline DOUGLAS
« Reply #6 on: July 20, 2017, 04:58:00 AM »
when i first bought it i thought i could use it as is. i soon discovered that in order to even get a 4 wheeler on it the deck height was to high. then i thought i would use 2 x 10 planks on the floor so it would raise the bike up and then just put blocks under the frame of the bike. it was not a practical approach. could have cheaped out and not used stainless but how many times do you convert a motor cycle lift. and the stainless looks awesome. to any who want to buy a lift total cost to me was $ 940. you can buy an atv lift for around that then there is a shipping cost.
