Author Topic: Chains  (Read 4983 times)
Offline Grande huevos
Chains
« on: July 24, 2017, 11:39:03 AM »
Curious what kinda of chain people recommend. I have a 363 and I ride XC and hit the sand couple times a year. I previously ran the renthal z ring chain and it's been awesome, the only issue is it's thicker then other chains so you can't run a case saver with a 15T front sprocket and that's what I would like to do..
Also what are you guys running for sprockets? The only 15T I've been able to find is a sun star
« Last Edit: July 24, 2017, 11:47:30 AM by Grande huevos »
Re: Chains
« Reply #1 on: July 25, 2017, 02:14:22 PM »
Just straight steel sprockets front and rear and a DID ATV x-ring. Mine has held up great so far on my 350
Re: Chains
« Reply #2 on: July 25, 2017, 11:41:59 PM »
This is the same exact setup I use myself.
Re: Chains
« Reply #3 on: July 27, 2017, 08:44:38 PM »
Why not go down in the rear? As for chain I ran that setup even on my puma
Re: Chains
« Reply #4 on: July 28, 2017, 09:11:36 AM »
Far as the case saver goes, I would get the UPP and a dremel and carve it out to fit. I did it in a few spots on mine
Offline JohnTabata1
Re: Chains
« Reply #5 on: July 30, 2017, 05:05:58 PM »
I use DID
