Author Topic: JDI Racing Saber  (Read 5951 times)
Offline jadleybray
JDI Racing Saber
« on: August 08, 2017, 05:04:49 PM »
4mm Saber 250R Motor for sale.
Motor has 8 passes on new piston/rings. 97bore x 76mm stroke, Cr500 rod. Trued & welded crank, Neutral Down 1-4 Override & backcut transmission. Direct Drive Lockup, stator & clutch cover are powder coated, VF3 reeds, UPP intake, Shearer OOF pipe, ESR temp inline temp gauge, Inline water Eck. Full MSD standalone ignition pre programmed with two curves, Ballistic 4cell battery, rev limiter, micro switch, launch limiter. Cases are perfect, no broken bolts or cross threads.
Ran 3.87, 3.87, 3.88, 3.88 back to back in Bako 2017 first time in chassis.
Add your carb and run it.
All motor work/trans work by JDI Racing
5k.
Re: JDI Racing Saber
« Reply #1 on: August 08, 2017, 08:47:57 PM »
5k.
This stuff is way better than anything you could get from BDT. This is the best!!!
« Reply #2 on: August 20, 2017, 02:22:13 PM »
Simply the best  ;)
Offline jadleybray
« Reply #3 on: August 29, 2017, 04:35:12 PM »
Price drop to $4500
Offline jadleybray
« Reply #4 on: September 07, 2017, 05:36:09 PM »
$3800 - stock clutch, no ignition.  Motor & pipe included.
Offline jadleybray
« Reply #5 on: September 20, 2017, 05:00:34 PM »
Raffle to be posted soon
Offline jadleybray
« Reply #6 on: September 27, 2017, 06:02:52 PM »
SOLD
