Author Topic: Parts cleanout! 250R is gone, need to sell all this stuff!  (Read 11016 times)
Offline desertR
Re: Parts cleanout! 250R is gone, need to sell all this stuff!
« Reply #15 on: August 18, 2017, 03:41:34 AM »
Items came today, in good condition, and as described. I'll check fitment in a few day's as I have time, but all looks good.
Thanks
desertR  / Kary
Offline jwraymond6
« Reply #16 on: August 18, 2017, 01:43:30 PM »
Pm sent
Offline jwraymond6
« Reply #17 on: August 21, 2017, 04:20:46 PM »
Payment sent
Offline desertR
« Reply #18 on: August 24, 2017, 12:00:19 AM »
More on this, the ASV lever works/fits great and will be a good addition.
VAPOR - seems to be in good condition, but I'm unable to test it at this time(no fault of seller). I did order $109.00 worth of stuff for it today, as I do believe it will work fine when installed. In this build, I'll be monitoring both cylinder head temps, and oil temps and have a A/B type switch to switch between both temp sensors on the fly. These electronic type gizmo's, while cool, are spendy to make work how you want. I built a mold and filled the caliper mount with JB weld epoxy so the speedo sensor fits correctly, drilled/tapped the caliper mount for 4mmx.7mm to hold the sensor correctly, but waiting for parts to test.
To all;   I would not hesitate to buy from this seller, and need to look and see if there is more I can purchase from him.
desertR
« Reply #19 on: August 26, 2017, 04:45:50 PM »
Got the hand guards yesterday. Thanks Jimbo45.
Offline jwraymond6
« Reply #20 on: August 30, 2017, 01:01:58 AM »
Shock came today thanks again
