Author Topic: bearing placment  (Read 2655 times)
Offline sam mc 2000
bearing placment
« on: August 04, 2013, 11:00:03 AM »
Ok guys i took my case halfs apart and i had a few bearings fall out i have one i am not sure on location and direction so here are some pics of the bearing and where i think it goes please let me know what you think. Also i posted about some dings on the center case where the crank is seperated from the tanny u can see the dings in the pics let me know what u think about if those are going to be a problem or not thank you for any and all help
« Last Edit: August 04, 2013, 11:23:54 AM by sam mc 2000 »
Offline Victork
bearing placment
« Reply #1 on: August 04, 2013, 12:18:02 PM »
If none of your bearings came out of the right case then yeah, right there. The yellow seal side goes in first.
Offline Victork
bearing placment
« Reply #2 on: August 04, 2013, 12:22:11 PM »
If none of your bearings came out of the right case then yeah, right there. The yellow seal side goes in first. You might want to take the yellow zeal off so oil can lubricate the bearing better and get through to lube the clutch actuator rod better through the little hole. Might want to ask neil or let someone who knows 100% chime in.
bearing placment
« Reply #3 on: August 04, 2013, 01:03:06 PM »
generally you dont want bearings fallin out on their own
