Author Topic: CT 350 PV thoughts  (Read 4254 times)
Offline mwiley
CT 350 PV thoughts
« on: October 25, 2017, 04:53:00 PM »
Hey guys,
Just looking for some opinions on the CT 350 PV motor package. I am looking at buying a used one and would be using this as an all around motor, trail, dunes, play riding. I was told it has their basic mid-range porting with a 39mm carb and v-force reeds and is on the 2nd bore. Any input would be appreciated on this motor or CT stuff in general.
Mike
Offline Michael88R
Re: CT 350 PV thoughts
« Reply #1 on: October 26, 2017, 10:16:05 AM »
If it’s in good shape and u want a good all around big bore engine, then it’s a good set up.  Don’t expect it to be the fastest thing around ur should have good power top to bottom and be easy to keep it in the powerband.  I wouldn’t overpay for the powervalve.  I’ve had a few and they don’t seem to work that great.  If the price is right, go for it.
« Reply #2 on: October 27, 2017, 09:59:23 AM »
Make sure the price is very right or you should consider going with the esr options.
« Reply #3 on: October 27, 2017, 01:16:41 PM »
I wish I had mine all together to give you a ride report off this very engine.
« Reply #4 on: November 09, 2017, 10:49:44 AM »
Mike, you'll do good getting the CT, cause you got to remember it is a Pro-x cylinder & those cost 2 times what an ESR top end will cost. Even though it is their basic mid range porting, it will be quite a bit better than the regular generic porting of the ESR cylinders, but If Eddie does the porting himself, then the ESR would be a match to the CT cylinder.
Far as performance, find out how much compression the cylinder has & if its kinda low, up the compression & you should be well pleased with the performance. Have the cylinder ported again for like say upper mid range & the valve will give you pretty good bottom end, but when the valve opens, hang on cause your going for a ride.
« Last Edit: November 09, 2017, 10:51:23 AM by C-Leigh Racing »
