Author Topic: starting my build  (Read 134498 times)
Offline DOUGLAS
Re: starting my build
« Reply #15 on: December 24, 2017, 11:57:18 AM »
another photo
LED 363 87 stock frame
Offline DOUGLAS
« Reply #16 on: January 01, 2018, 10:54:33 AM »
front end assembly ]
Offline DOUGLAS
« Reply #17 on: January 01, 2018, 10:55:22 AM »
another photo
Offline DOUGLAS
« Reply #18 on: January 01, 2018, 05:44:58 PM »
Douglas Hoyt well as expected the toe in is off considering I got a arms 2 plus 1 with tie rods plus 2. but I am using 06 450 spindles. facing the bike the right side is nearly spot on as far as toe. the left is out about 3/4 inch. my tie rods are 14 inches atv guy has a few sets standard and plus 1 he is gathering for me tonight so I will go pick pick them up as he is only 1 mile from my house. I also can take a little off the tie rod end itself about 1/4 to 5/16 with a hack saw that will give about an additional 5/8 - 3/4 inch adjustment. my a arms have all heim joints so I have maximum adjustment available to me.
Offline DOUGLAS
« Reply #19 on: January 04, 2018, 08:25:52 PM »
update using the plus 2 tie rods I have for the arms 14 inch I cut of 1/4 off each tie rod end on left side that gave me enough to bring in my toe enough to match up with the right side. so i'm off to a great start considering most every one has always said 04-05- 450 spindles the 06 and up are a problem or won't work. I just got my swing arm and gas tank back from the welder and I will be sending it out to the dave at race reflections to be repolished. I am waiting for him to finish a few parts before I send these out. so for now here's some eye candy
« Reply #20 on: January 04, 2018, 09:39:20 PM »
That is a very nice clean build buddy.
Offline DOUGLAS
« Reply #21 on: January 14, 2018, 11:06:03 AM »
a little mod for my foot lever. added a grease fitting and a cr450 toe tip
« Reply #22 on: January 14, 2018, 11:32:13 AM »
good stuff Douglas
« Reply #23 on: January 15, 2018, 07:22:37 AM »
Did you cycle the suspension through the entire range to see if it toes out at the top of the travel?
Offline DOUGLAS
« Reply #24 on: January 15, 2018, 11:30:11 AM »
waiting on my swingarm so I can put her on the floor to make all adjustments. i sent it to race reflections.. in jackson tn. he wont receive it till tomorrow and i am leaving for a 10 day vacation on a cruise so it will be a bit before i can get to it.
« Reply #25 on: January 15, 2018, 02:56:17 PM »
Before you put the shocks on it,  Put the tires/rims on and cycle the suspension and measure the toe at the bottom and top of the stroke and see how much it changes.   Im pretty curious on this, as i was under the impression the 450r stuff wont work on the 250r unless you change the flag height.
« Reply #26 on: January 15, 2018, 03:28:06 PM »
By the look of the angle of the tierod in the pics. It will have some issue. They are not the same angle as the arms. Just my uneducated observation
« Reply #27 on: January 15, 2018, 03:46:18 PM »
I believe you are correct.  however, the 400ex stuff should work.  I believe there is a bracket that allows the use of the 250r dual piston calipers.
Offline DOUGLAS
« Reply #28 on: January 15, 2018, 04:27:50 PM »
all good stuff guys. I will exercise all options and tests to try to dial in this girl. at the moment all bolts are finger tight. thank you all for your thoughts and interest. I already made some correction to the toe after this photo was taken.
« Reply #29 on: January 16, 2018, 01:56:00 PM »
You have adjusted toe at full extension right?  Measure it at full up travel and ride height.  You might not like what you see.
