Author Topic: starting my build  (Read 133554 times)
Re: starting my build
« Reply #60 on: February 16, 2018, 09:11:42 PM »
Very cool
« Reply #61 on: February 17, 2018, 08:04:50 AM »
that looks great.  RIP DnB
Offline DOUGLAS
« Reply #62 on: February 19, 2018, 06:37:28 PM »
its here led 350 G
LED 363 87 stock frame
« Reply #63 on: February 20, 2018, 02:10:08 PM »
Let's get that in the frame!
Offline DOUGLAS
« Reply #64 on: February 20, 2018, 08:31:27 PM »
its gonna be a bit. i'm waiting for some parts for my linkage. won't be seeing that till next week. then I will have a roller if I can figure out adjustments with these 450 components. after that i can install my motor
Offline DOUGLAS
« Reply #65 on: February 24, 2018, 08:43:34 PM »
its a roller. but I got a lot of tweaking to do.
« Reply #66 on: February 24, 2018, 09:10:30 PM »
Keeps getting closer
Offline Sand_Blaster
« Reply #67 on: February 24, 2018, 11:13:08 PM »
It looks good. Man that swing arm looks chrome, but its polished.
87 Trx250r & 99 Banshee
Offline DOUGLAS
« Reply #68 on: March 04, 2018, 11:50:21 AM »
here's I trick I came up with. i drilled a 5/8 hole so I can grease my 450 carrier I installed in my 87 250r. just loosen the carrier bolts rotate fitting to hole apply grease. I made a rubber plug to keep debris out.
Offline DOUGLAS
« Reply #69 on: March 04, 2018, 12:14:17 PM »
here's my 06 450 swing arm installed on my 87 250r
Offline DOUGLAS
« Reply #70 on: March 04, 2018, 12:28:07 PM »
06 450 spindle hub conversion on my 87 250r
Offline DOUGLAS
« Reply #71 on: March 04, 2018, 12:37:00 PM »
here is my 87 250r with 06 450 swingarm . o6 front spindles hubs and shocks ready to install my LED 363
« Reply #72 on: March 04, 2018, 09:25:43 PM »
Looking sick! Can't wait to see that exhaust mounted up
Offline DOUGLAS
« Reply #73 on: March 05, 2018, 06:12:24 AM »
I had to send expansion chamber back to LED there were some blemish's in the chrome. also I am having them make an adjustment for me oin the LED stamp plate they use. the new one will be a trick set up. 1 of a kind I had to talk Arlen into it. I will post a pic when I have it installed.
« Reply #74 on: March 05, 2018, 06:21:05 AM »
douglas, something doesn't look right on your front end.  doesn't look like your top ball joints are fully seated in the spindle.  could it be an optical illusion?
