Author Topic: starting my build  (Read 135517 times)
Offline DOUGLAS
Re: starting my build
« Reply #90 on: March 11, 2018, 01:43:38 PM »
parts table dwindling
LED 363 87 stock frame
Offline DOUGLAS
« Reply #91 on: March 13, 2018, 10:40:00 AM »
how do I fix this carb alignment ?
« Reply #92 on: March 13, 2018, 10:49:30 AM »
What intake boot/manifold are you using? That is way way off
« Reply #93 on: March 13, 2018, 11:05:02 AM »
CR intake
« Reply #94 on: March 13, 2018, 11:13:53 AM »
any chance you have the intake upside down?
Offline DOUGLAS
« Reply #95 on: March 13, 2018, 11:52:18 AM »
another pic
« Reply #96 on: March 13, 2018, 11:52:45 AM »
Looks like you have a really thick reed spacer on you engine & with the angle of the intake on the cylinder the thicker the spacer used the higher it raises the carb. Since your not running an air box there's no need to run such a thick spacer. There made more for alignment purposes than performance.
« Last Edit: March 13, 2018, 11:56:29 AM by broken1 »
Offline DOUGLAS
« Reply #97 on: March 13, 2018, 11:54:39 AM »
I sent all my parts to Arlen I'm sure he set it in right. the intake is from esr. it came with the 370 kit I bought from him about 5 years ago.
Offline DOUGLAS
« Reply #98 on: March 13, 2018, 11:55:55 AM »
yes this is what I see as well.. heat gun on the intake ? and cut a little on the frame ?
« Reply #99 on: March 13, 2018, 11:56:42 AM »
that large of an intake spacer is strange.  does arlen has reasoning behind it?
« Reply #100 on: March 13, 2018, 11:57:50 AM »
No to either option. Option 3 is to get a thinner spacer until the carb bell drops low enough to clear the frame.
« Reply #101 on: March 13, 2018, 12:12:09 PM »
After looking at the side pic of your carb a little closer I don't see the tell tale parting line between what would be the spacer & reed cage. Is that really how thick your reed cage mounting flange is or is there no reed cage in your engine & just a thick black spacer?
Offline DOUGLAS
« Reply #102 on: March 13, 2018, 12:15:39 PM »
that is the esr reed cage mounting flange,
« Reply #103 on: March 13, 2018, 12:38:58 PM »
I would take that reed block out and machine half off!
Offline DOUGLAS
« Reply #104 on: March 13, 2018, 12:50:55 PM »
maybe just switch to a v force. I runn that on my banshee
