Author Topic: How to tell whether I have +1 +2 or +3 A arms, swingarm and axle  (Read 2961 times)
Offline dcs1968
« on: December 16, 2017, 12:33:48 AM »
I was wanting to know if anyone could tell me what the stock measurements are for the A arms, swingarm and rear axle. I have aftermarket A arms and a Durable axle, not sure about the swingarm.  Thanks in advance for any direction anyone can offer.
Re: How to tell whether I have +1 +2 or +3 A arms, swingarm and axle
« Reply #1 on: December 16, 2017, 07:51:59 AM »
here is some axle specs.
Offline Sand_Blaster
« Reply #2 on: December 16, 2017, 11:18:54 PM »
I see you posted on .net as well and looks like you got your answer. But my +2's are 15" and my +3's are 16". Kind of looks like you got +2's.
87 Trx250r & 99 Banshee
Offline dcs1968
« Reply #3 on: December 17, 2017, 01:56:37 AM »
Thank you for the replies. I did post on net as well and then I started to notice that they were not as active as org. I am not trying to dis anyone as I value the info I can get from both. Happy Holidays and Merry Christmas.
« Reply #4 on: December 22, 2017, 01:10:44 AM »
Your swingarm is 86-87 OEM. Sounds like you got the width of the a-arms figured out but if you don't know how to tell if there +1" forward or not look at where the shock is mounted on the lower a-arm. If the shock is basically in the middle of the arm front to back there +1" forward. If the shock mounts toward the front of the a-arm there standard wheelbase arms.
« Reply #5 on: December 27, 2017, 12:58:32 PM »
The  rims are on backwards.  You will  experience  far less  feedback through the  handle  bars with a  proper wheel  offset.
