Author Topic: Exhaust issues  (Read 4411 times)
Offline Red89
Exhaust issues
« on: February 06, 2018, 08:20:48 PM »
My exhaust pipe is touching my rear radiator hose. I've read that it's not abnormal for this and it will be ok, however it is touching it enough that it is starting to pintch the hose. Is that normal? What do your guys' look like? Thanks!
Re: Exhaust issues
« Reply #1 on: February 07, 2018, 12:25:37 AM »
What pipe are you running? It could be just an alignment issue. I had an FMF pipe that hit the hose but after taking it off & spending a little more time lining it up I finally found the sweet spot & now there's 1/4" clearance.
« Last Edit: February 07, 2018, 08:48:02 PM by broken1 »
Re: Exhaust issues
« Reply #2 on: February 07, 2018, 05:10:24 AM »
broken explained the likely culprit.  if you can mount it all the way back with the silencer bolt in, then start installing the springs.  you might need an extra set of hands to do this.
John
Re: Exhaust issues
« Reply #3 on: February 07, 2018, 02:54:31 PM »
Like the other guys stated. I would play with the exhaust a bit. You can also twist the rad hose one way or the other so it turns out and away from the pipe.
What mounts are you using? Post up some pics if you can
Offline Red89
Re: Exhaust issues
« Reply #4 on: February 07, 2018, 04:32:01 PM »
Come to find out I had the wrong hoses on for the job and ordered the correct hoses. This should help. If not I will put a spacer on the mount for the pipe on the front motor mount.
