Author Topic: Laeger protrax extended steering stem  (Read 8998 times)
Offline JDF Rex
« on: February 16, 2018, 11:47:11 AM »
As title states, looking for an extended stem, +2 or +3. Has to be for protrax- Clevis style.
Re: Laeger protrax extended steering stem
« Reply #1 on: February 16, 2018, 06:12:19 PM »
what happened to the stem?  you cant buy the pro-trax parts separate.
Offline JDF Rex
« Reply #2 on: February 16, 2018, 07:05:36 PM »
Nothing happened to the stock length stem, I'm looking for an extended height stem. I want it to be the clevis style and not the oem style. Not looking for parts, just the extended clevis  style stem.
Thanks
« Last Edit: February 20, 2018, 10:37:59 AM by JDF Rex »
« Reply #3 on: February 20, 2018, 01:34:09 PM »
you will need to get bar risers then.  unless laeger would make you one, but it is unlikely.
« Reply #4 on: February 20, 2018, 04:36:05 PM »
You might be able to send it to someone to have it extended. JD & Lonestar will add an antivibe top to whatever stem you send them so someone that knows what their doing should be able to extend the one you already have.
Offline JDF Rex
« Reply #5 on: February 20, 2018, 10:35:09 PM »
Was wishfully thinking that someone out there would see the post and think they wanted a stock length and want to trade for their extended length. I know,  wry wishful but worth a shot. Thanks for the suggestions, if all else fails I may just sleeve it and add length to the one I have.
« Reply #6 on: March 06, 2018, 11:08:21 AM »
Six 5 Design turned my old standard length Laeger stem into a +3+1. Did a hell of a job too
Offline JDF Rex
« Reply #7 on: March 06, 2018, 11:51:47 AM »
Can you send me pictures? I'm very interested. Feel free to text if you prefer.
760-455-4315 thank you
« Reply #8 on: March 06, 2018, 12:20:11 PM »
check this out;
« Reply #9 on: March 06, 2018, 12:28:41 PM »
Might get lucky if HSD Racing has any around - they're a bigger Laeger's dealer.
« Reply #10 on: March 06, 2018, 01:02:07 PM »
check this out;
This might be your better option JDF. I know Six 5 Design does work as he can, and is always busy traveling. I got real lucky.
If JD does it, you'll at least have a guy with Laeger in his blood.
Offline JDF Rex
« Reply #11 on: March 06, 2018, 03:15:58 PM »
HSD reached out to France(Laeger) and they are looking for the jig. It might happen but then again it might not. I've also reached out to Steve Buchinsky(spelling?) and he might make them one day down the road. I'll contact JD and see what they have to say. Thanks for that info.
T-bone, I also called six 5 and left a message. This isn't something I need until next fall so time isn't of the essence.
I'd prefer using a shop with atv experience rather than my local machine shop but I guess that's always an option as well.
Thanks for all of the info
« Last Edit: March 06, 2018, 05:57:12 PM by JDF Rex »
« Reply #12 on: March 06, 2018, 04:50:28 PM »
I found out when talking to Dave @ JD, that he was the one that actually welded my no-link Laeger frame back in '97. I couldn't get Laeger's to make me a-arms, but it felt great knowing the a-arms I ended up buying were fabricated by the guy who made my frame.
If anybody knows about ProTrax stems it should be Dave.
