Author Topic: Laeger's Pro-Trax Shock Bolt & Nut  (Read 12103 times)
« on: March 13, 2018, 04:55:37 PM »
All, the lower shock mount on the Pro-Trax (and assuming LT Laeger) uses a smaller head for the bolt and nut so theres room for the socket.  Anybody know what these P/N's are?
Re: Laeger's Pro-Trax Shock Bolt & Nut
« Reply #1 on: March 13, 2018, 08:59:58 PM »
Ryan, I believe they use a socket head cap screw. I'll check my notes
Offline matt250r21
« Reply #2 on: March 13, 2018, 10:05:03 PM »
On mine I think I used a M10 x 65 1.25 pitch allen bolt and a regular 10mm flange nut with 14mm hex head on the nut. Not sure if 65mm is the right length I cant remember for sure.
« Reply #3 on: March 13, 2018, 10:51:29 PM »
I don't have a protrax, but I do know you can get mini head jis flange bolts and nuts at ace hardware and wilco farm store.
« Reply #4 on: March 14, 2018, 04:23:37 AM »
I was able to use titanium hex head screws but, i needed a thin wall socket to tighten it.
« Reply #5 on: March 14, 2018, 12:45:52 PM »
Thanks all - a few different options but really looking for the actual honda p/n's - @witz gave me these 10 years ago and thought I had them tucked away but cannot find them.
« Reply #6 on: March 14, 2018, 01:55:55 PM »
@Langbolt
he might have the info
« Last Edit: March 14, 2018, 02:31:53 PM by havinnoj »
Offline bnau267
« Reply #7 on: March 18, 2018, 09:46:15 PM »
Pretty sure I use 300ex a-arm bolt Part# 90183-HC0-770.
I think I grind the flange down just a little.  It’s been a while.
« Last Edit: March 18, 2018, 09:49:06 PM by bnau267 »
Offline bnau267
« Reply #8 on: March 18, 2018, 09:49:47 PM »
300ex a-arm bolt
« Reply #9 on: March 19, 2018, 02:12:47 AM »
Thanks Bob.  300ex nut too I assume?
« Reply #10 on: March 22, 2018, 08:14:09 PM »
@Langbolt
I do! TRX450 rear shock bolt.....the flange is the perfect size....fit's like OEM
BOLT, SPECIAL FLANGE (10X58)
Part# 90153-965-010
« Reply #11 on: March 23, 2018, 12:09:57 PM »
@Langbolt
Part# 90153-965-010
Thank you sir!  @Langbolt - does the matching nut fit as well?
« Reply #12 on: March 23, 2018, 01:16:55 PM »
Yes! The matching nut works as well.....Part# 90305-HC0-770
« Reply #13 on: March 23, 2018, 07:16:35 PM »
Thank you sir!
Offline bnau267
« Reply #14 on: March 24, 2018, 07:33:56 PM »
i'm gonna have to try the 450 bolt someday.
