Author Topic: 36mm PWK Jetting  (Read 9665 times)
36mm PWK Jetting
« on: March 19, 2018, 02:12:12 PM »
does anyone have ballpark/baseline jetting for a 36mm carb?  specifically, a 36mm pwk.
thank you,
John
Re: 36mm PWK Jetting
« Reply #1 on: March 21, 2018, 06:43:27 AM »
no one running a 36mm?
« Reply #2 on: March 21, 2018, 09:49:27 AM »
I'll have to look up my specs from years past when I had a 36mm. I have a 38mm now. I know they're pretty similar, but I can't remember the 38mm specs either.  :(
Offline wilkin250r
« Reply #3 on: March 21, 2018, 01:12:07 PM »
I bought a 35mm PWK A/S a while back, it came with a 160 and a 48 pilot, and that was pretty dang close.  I think I'm running 162, and the same 48 pilot.
My logic says if the 35mm was so close, then I would estimate the 36mm would ALSO be close, and it would come with a 165main and 55 pilot.
« Reply #4 on: March 23, 2018, 08:10:43 PM »
after talking to carb parts warehouse.  it was suggested a 35mm was a better choice for my application.
Offline wilkin250r
« Reply #5 on: March 26, 2018, 09:36:46 PM »
I'm pretty happy with my 35mm.  I was specifically looking to boost the low/mid, and also hold the top end back a little.
The low/mid is definitely there, throttle response is good, and it really didn't choke the top end as much as I thought it would, I'm still constantly bouncing off the rev limiter in the lower gears.  Engine is stock bore, stock porting, with a basic FMF pipe.  I built it to run along side a piped 400EX, as a basic trail machine, and it still walks away from the 400.
Totally happy with my 35mm, this is a fast, peppy little trail machine.
Offline wilkin250r
« Reply #6 on: September 12, 2018, 02:38:06 PM »
Did you ever get that 35mm up and running?  How do you like it?  What kind of build was it?
« Reply #7 on: September 12, 2018, 02:40:31 PM »
It is on the back burner.  i had another kid and that has been taking up free time.
I intend to get back to it soon.  it is just a 250cc gasgas in the other ATVs section.  I am just about finished getting the pipe figured out so i will move onto the intake side.
Offline brad luna
« Reply #8 on: August 11, 2020, 01:31:18 PM »
i run a 36 pwk my jetting is 158> main and 50> pilot  I live in missouri .
