Author Topic: FIRST RIDE OF THE SEASON TODAY  (Read 6361 times)
Offline DOUGLAS
« on: May 05, 2018, 09:11:53 PM »
weather was excellent today mid 70's mostly sunny slight breeze not hot not cold.
atvguy and myself went out riding for about 4 hours of ride time. diden't take to many breaks all woods mostly technical trails and a few balls out trails. atvguy had 1 of his 10 250r bikes out he calls his woods beater. front sprocket kept loosing up. but we did not have any major catastropies. my 4 mil banshee was spot on today ripping through the faster trails 5th and 6th gear front end coming up exzillerating. like tunnel vision. I got a little wheel wobble at close to top end. gonna have to take a look at that. I will probable wake up tomorrow in a coma for me at 59 years old i'm gonna feal it.
« Last Edit: May 07, 2018, 01:45:02 PM by Tbone07 »
LED 363 87 stock frame
Re: FIST RIDE OF THE SEASON TODAY
« Reply #1 on: May 05, 2018, 10:54:58 PM »
nice!! I can't wait for my first ride of the year
« Reply #2 on: May 07, 2018, 01:07:05 PM »
my first ride of the year will probably be at winchester:(
« Reply #3 on: May 07, 2018, 01:18:24 PM »
I need to bore a cylinder and replace a piston to have my first ride.  too much piston slap for comfort.
Offline Sand_Blaster
Re: FIRST RIDE OF THE SEASON TODAY
« Reply #4 on: May 07, 2018, 02:53:55 PM »
Pics Doug?
87 Trx250r & 99 Banshee
Offline DOUGLAS
« Reply #5 on: May 07, 2018, 05:53:51 PM »
here's some pics of my banshee. herr jugs build 4 mil stroker toomy t-5 yfz shocks  38 carbs. c-12 vp straight up. no pics of riding. I still have a flip phone
« Reply #6 on: May 07, 2018, 05:58:52 PM »
A friend of mine just picked up a 4 mil banshee that was built by lrd
Offline desertR
« Reply #7 on: May 07, 2018, 07:29:34 PM »
Question for you, How wide are the extensions on your lift ? I have the same unit (HF) and am going to build a set of extensions so my quads fit on the lift, I was thinking 12" ? 14" ? do you find the added ramps off the end necessary ?
Thanks
desertR
Offline DOUGLAS
« Reply #8 on: May 07, 2018, 09:04:22 PM »
the ramps are a must. I tried to lift the bike on it and fu-- that. here are some pics on how I did it. I also cut a little off the front and the back so to down size it to fit the area I use it in. I drilled through the frame of it and put in 1 inch sold steel bars for support. on the top of the table there is a lip that is vertical about 3/4 inch I attached the extensions to that with 1/4 20 bolts. also the 1 inch bars are bolted directly to the side of the extensions. I also had to make an exstension for the foot pump. I have not made one for the release on as of yet. the side exstensions are made out of stainless 1/8 th it works awesome for what I need it for.
Offline DOUGLAS
« Reply #9 on: May 07, 2018, 09:06:02 PM »
as far as how wide I made the table wide enough to put a 50 inch wheel base.
Offline desertR
« Reply #10 on: May 07, 2018, 09:51:38 PM »
Thank you
I've seen them anywhere from 48" to 55" wide and many racing sanctions/tracks limit width to 48" so I figured that would be a good starting width. Similar mounting is normal, but solid bar stock seems overkill and heavy, but you use what's handy. I hadn't figured in ramps, but don't want to lift anything that awkward or heavy either, So I'll add ramp materials to the list. I think I remember seeing pic's of the underside of the lift, but thanks for those.
desertR
