Author Topic: 2Nubs's boondock build  (Read 51647 times)
Offline 2Nubs
« on: August 02, 2018, 11:28:36 AM »
Been getting some good help from several members here. Think it might be helpful for me to make my own thread and maybe cool to look back on one day and see where I started.
Most of you know the run down. Bought this and afterwards realized the frame was junk. Its completely disassembled right now so of course I found things that should be fixed before re-assembly. Hopefully I can have it back going in a week or so. I've not even put a tank through this thing, but I can honestly say I know it from top to bottom and side to side. Everything is getting a good cleaning as well. Sand gets into everything!
1986 250R, Washington title.
MODS:
ESR 330, pump dome (100 octane, Klotz ST)
ESR 39mm PWK (185 main, CGJ 2nd clip, 48 pilot)
ESR airbox eliminator/intake, UNI/Outerwear
ESR Trx9B center mount pipe/silencer
CR250 ignition
ESR coil mount
ESR ignition adaptor plate
VForce 3
AFCO big radiator w/AN connections (Engine Ice)
ESR water pump cover
ESR shifter and brake pedal
Lonestar +2+1 A arms w/ Moog upper/lower ball joints
Lonestar '86 swingarm -1 (18.5")
Lonestar Axcalibar axle
Lonestar billet sprocket hub
Lonestar forged carrier
Lonestar billet wheel hubs
88/89 spindles
NOS front calipers
Riptide rotors
Works triple rate front shocks
OEM revalved rear shock
Maier plastics
Alba bumper
Renthal 787's and clamps
ASV levers
ODI grips
TM Designworks slide N guide
DID 520 x ring
Hiper CF1's 10x5, 10x10
« Last Edit: September 24, 2018, 11:46:41 AM by 2Nubs »
‘86 330
Offline 2Nubs
Re: 2Nubs's boondock build
« Reply #1 on: August 02, 2018, 11:34:58 AM »
This is what started the tear down..
Hopefully my replacement frame will be on the way tomorrow. Ceaserthethird sold me a cherry looking '86 frame. I also took the time to rebuild the petcock with OEM rubber, new clear Helix fuel lines, high flow filter, and a new screen in the tank.
Things I still need are a lower engine mount bolt and nut. One bolt for caliper to brake stay. One bolt for parking brake block off. New tires (not many options for a 10" rear wheel). One bolt for a arm to frame. Full set of chain sliders/rollers.
« Last Edit: August 02, 2018, 12:54:33 PM by 2Nubs »
‘86 330
Offline 2Nubs
« Reply #2 on: August 02, 2018, 11:35:07 AM »
Reserved..
‘86 330
« Reply #3 on: August 02, 2018, 12:08:11 PM »
you getting all new chassis bearings?  i would recommend doing so.
Offline 2Nubs
« Reply #4 on: August 02, 2018, 12:50:42 PM »
You mean like the swingarm? I think they might just need a shot of grease. The needles seem good. The a arms seem like new and will also receive grease. There is also a steering stem bearing, correct? Seems like there is some linkage bearings that aren't manufactured anymore as well.. Thanks for the help!
« Last Edit: August 02, 2018, 12:57:49 PM by 2Nubs »
‘86 330
« Reply #5 on: August 02, 2018, 01:48:07 PM »
I would just replace them all.  It might be a while before you get the chance to do it again.
Offline 2Nubs
« Reply #6 on: August 02, 2018, 02:29:59 PM »
I wonder if these are Lonestar specific or just factory? For the a arms and swingarm that is
‘86 330
Offline 2Nubs
« Reply #7 on: August 08, 2018, 10:03:52 AM »
ATVGuy helped me find some hard to locate bolts. Very little parts needed now. 2 Zerks fittings for the top ball joints, a Banshee style chain guide, an upper chain roller, and putting this thing back together. I can't wait to smell that smoke!
‘86 330
« Reply #8 on: August 08, 2018, 06:26:58 PM »
looks like its coming along nicely
Offline 2Nubs
« Reply #9 on: August 09, 2018, 09:56:28 AM »
Figured I would share the new tag. Relevant to the forum I suppose, as well as a pic of my mutts (no tails, get it?) in case anyone was thinking I had lost fingers haha.
No other pics to post unfortunately. Some more OEM parts have arrived and a nice quick cut off nozzle and filler hose for my VP fuel jug, but that's about it.
‘86 330
Offline DOUGLAS
« Reply #10 on: August 09, 2018, 12:14:26 PM »
good call on the chassie for sure not alwys going to be tirn down best to replace the bearins and all
LED 363 87 stock frame
Offline 2Nubs
« Reply #11 on: August 09, 2018, 12:21:23 PM »
Got a p/n for steering stem and swingarm bearings. Going to order those. A arms bushings and heims are either new or fresh rebuilt as well as ball joints. Carrier and axle bearings, seals all brand new.
‘86 330
« Reply #12 on: August 09, 2018, 01:24:47 PM »
It will not be long now. You got some looking dogs there. Dobermans are cool
Offline 2Nubs
« Reply #13 on: August 09, 2018, 01:58:46 PM »
Thanks Gene. It only took them 6 years to calm down haha. They good dogs though, if I do say so myself.
Feel like I'm forgetting something... I keep re checking my parts list though and I should be good to go. I'm going to tinker some more tonight and I'll probably run across something small that I need.
‘86 330
« Reply #14 on: August 09, 2018, 06:33:05 PM »
i use All balls for the stem bearings.
