Author Topic: Hiper wheels  (Read 10900 times)
Hiper wheels
« on: August 29, 2018, 05:39:20 AM »
So I'm thinking about getting a set of hiper wheels. Looks like can still get the cf1's through atv galaxy. Hiper's site doesn't list them anymore. So my question would be what is the benefits of the tech 3's over the cf1's
Offline 2Nubs
Re: Hiper wheels
« Reply #1 on: August 29, 2018, 06:45:00 AM »
The tech3’s carry a longer warranty and are better suited for mx/gncc I have read. I have also read of oblonged mounting holes on the tech3. They are suppose to be stronger though.
‘86 330
Re: Hiper wheels
« Reply #2 on: August 29, 2018, 07:37:40 AM »
The Tech 3's have a billet center, the portion that mounts to the hub. CF1 is straight carbon fiber, with metal inserts where the holes are.
I have dual bead-lock Tech 3 rears that have been phenomenal. They still have the 5lbs of pressure in them that I originally filled them up with 3 years ago.
I have fought tooth and nail with one of my CF1 fronts almost since the day I bought them. One leaks between the tire and the bead-lock ring. I just ordered new rings so we'll see if that fixes the problem. Also possible the cheap GBC tires I use have an imperfection that's causing the leak. I'll find out this weekend.
You can see the diffrence here:
« Last Edit: August 29, 2018, 07:41:46 AM by Tbone07 »
Offline 2Nubs
Re: Hiper wheels
« Reply #3 on: August 29, 2018, 08:16:49 AM »
I really hope I don’t have issues with my cf1’s. Both are such a good looking wheel.
Tbone how’d you get that dent in your pipe?
‘86 330
Offline atvmxr
Re: Hiper wheels
« Reply #4 on: August 29, 2018, 08:53:26 AM »
same story here.  I have 5 sets of hipers and randomly 2 wheels out of them leak like a sob
Re: Hiper wheels
« Reply #5 on: August 29, 2018, 09:37:51 AM »
It was like that when I bought it. I assume it's from someone's foot slipping off the kicker.
I would go with the Tech 3 on every corner if I had to do it again
Also: Highland Tire in PA has the best prices on Hipers, hands down.
Contact Matt @ 717-226-6022
« Last Edit: August 29, 2018, 09:45:14 AM by Tbone07 »
Offline 2Nubs
Re: Hiper wheels
« Reply #6 on: August 29, 2018, 10:07:46 AM »
Yea, seems like the Tech3's are a superior wheel. Can't really see a draw back from what I've read.
With that said, my CF1's don't leak a bit and none of the rivnuts have spun out.
‘86 330
Re: Hiper wheels
« Reply #7 on: August 29, 2018, 11:18:09 AM »
Thanks for the replies guys. Ya I was planning on giving Matt a call
Re: Hiper wheels
« Reply #8 on: August 29, 2018, 02:37:17 PM »
I've never pursued Hiper's but curious if you want these for a sand setup Gene?  And if so, why?
Re: Hiper wheels
« Reply #9 on: August 29, 2018, 02:40:21 PM »
I like the look of them Ryan. I was also thinking about maybe omf beadlocks
Re: Hiper wheels
« Reply #10 on: August 29, 2018, 02:41:49 PM »
I do realize the extra rotating weight kills power. But my weight kills more
Offline Sand_Blaster
Re: Hiper wheels
« Reply #11 on: August 29, 2018, 02:50:00 PM »
I liked the look of mine. Heavy and two of them randomly leaked. They hold their value pretty good to I sold them for a good price.
87 Trx250r & 99 Banshee
Offline 2Nubs
Re: Hiper wheels
« Reply #12 on: August 29, 2018, 03:00:01 PM »
They are heavier than aluminum beadlocks? Guess I always assumed the point of them was to be lighter.
‘86 330
Re: Hiper wheels
« Reply #13 on: August 29, 2018, 04:46:31 PM »
Same here, but I'd prefer to not add any extra unneeded weight.  Though they look sweet!
Re: Hiper wheels
« Reply #14 on: August 30, 2018, 01:13:14 PM »
they are not worth the price in my opinion.  DWT aluminum beadlocks are just fine.
