Author Topic: 1986 trx 250r Pumashine gusset kit advice/pictures/info  (Read 6470 times)
Offline Ant1986250r
« on: January 19, 2019, 08:20:17 PM »
Hi I’m new to this site I have a 1986 TRX 250 R I’m completely tearing it down and I plan on getting a Pumashine  gusset kit I need advice on installation maybe pictures and heat treatment I was told anything helps thanks
« Last Edit: January 19, 2019, 08:22:23 PM by Ant1986250r »
Offline 2Nubs
Re: 1986 trx 250r Pumashine gusset kit advice/pictures/info
« Reply #1 on: January 19, 2019, 11:25:52 PM »
Welcome to the best R forum! Lots of great guys here that will help you out.
Looks like the pics aren’t showing up.. hmm I’ll notify a mod to look into it. I’ve seen these pics recently so I’m not sure what the problem is. Possibly a problem with the host.
https://www.forums.trx250r.org/index.php/topic,2777.0.html
‘86 330
« Reply #2 on: January 20, 2019, 10:58:26 AM »
Welcome to org.  We lost a lot of pics from photobucket and when the site upgraded.
No heat treatment required
Here are a few pics
« Last Edit: January 20, 2019, 11:00:29 AM by croat1 »
« Reply #3 on: January 20, 2019, 11:48:28 PM »
Welcome to the site.  Hopefully Tony can re-link those pics quickly - looks like they've been moved on the hosting site so might need to be re-uploaded in general.
Offline Ant1986250r
« Reply #4 on: January 21, 2019, 08:10:29 AM »
Thank you guys ! I just want to make sure while the bike is apart that it’s done right the first time . Do you guys recomend the standard or complete kit from Pumashine?
« Reply #5 on: January 21, 2019, 08:56:43 AM »
I have welded a few frames and gusset kits. It is important to use the correct wire size a voltage on your mig welder. What size welding machine will you be using? I use a miller 250 with.030 solid wire. I believe I was at around 17 volts(cant remember wire speed). I also used my TIG machine to fix some cracks and replace motor mounts. TIG looks better, but is slower and not worth it lol. I do not pre-heat or control the cool down. Good luck,  Loren
« Reply #6 on: January 21, 2019, 11:30:33 AM »
i would recommend installing all of the gussets, so a complete kit. you dont want to go strip your frame down later to gusset something you could have done the first time.
Offline Ant1986250r
« Reply #7 on: January 21, 2019, 07:24:40 PM »
Thank you I was kind of assuming that’s what I should do ! Do it right the first time while it’s all apart
« Reply #8 on: January 22, 2019, 01:12:46 PM »
Check the link, pics are back up.
« Reply #9 on: January 23, 2019, 05:01:32 PM »
See PDF attachment - feedback would be good to get.
