Author Topic: Polonda Motor  (Read 18680 times)
Offline liv2ride
Polonda Motor
« Reply #30 on: August 10, 2013, 10:09:49 PM »
Quote from: Polonda;8020
Do you have any way to measure the stroke?  Curious if its stock stroke or not.
No. Unfortunately not. I wish I has the tools and knowledge for that. The top end is as far as I get/have gotten into one, with basic shop tools laying around.
Offline Polonda
Polonda Motor
« Reply #31 on: August 10, 2013, 10:52:55 PM »
Any markings on the rod?
Offline liv2ride
Polonda Motor
« Reply #32 on: August 10, 2013, 11:12:39 PM »
Quote from: Polonda;8028
Hot Rods
C.K. 109
Polonda Motor
« Reply #33 on: August 10, 2013, 11:19:38 PM »
I sold my motor setup to Shane for $750 without a clutch or ignition. I believe its a good deal and worth $900 but this economy sucks. You can bore those out to 85mm and make a 431 out of it with a 4mil crank.
I myself would buy it and throw the Polaris cylinder away and put on a Puma or Shinx on that bottom end
Stripped drain plug is an easy fix.
Offline liv2ride
Polonda Motor
« Reply #34 on: August 10, 2013, 11:24:20 PM »
I'd like to get $800 shipped for it. I am open to any offers.
Im guessing shipping will be around $100
Polonda Motor
« Reply #35 on: August 10, 2013, 11:26:41 PM »
Don't know if any of you know brent mcmillen but he made a few polanda engines also. He had his own shop on hwy 22 for a while. He had a brother named kevin & they used to build some pretty fast 250R's. They built a 350R for a friend of mine that ripped.
Offline liv2ride
Polonda Motor
« Reply #36 on: August 10, 2013, 11:29:49 PM »
Do the cases have to be machined to accept the Polaris top end like they do for the big ESR's? There seemed to be plenty of clearance between the cases and the sleeve skirt on my 350 jug when I put it on there earlier. So I would think the cases have been machined.
Polonda Motor
« Reply #37 on: August 11, 2013, 12:23:42 AM »
Your cases have been machined. The Puma has to have the cases filled with epoxy and then machined. Any cylinder will work with your cases.
Offline Polonda
Polonda Motor
« Reply #38 on: August 11, 2013, 08:22:47 AM »
Quote from: Pumashine;8036
Instead of throwing the Polaris cylinder away, ship it to me.  :D
