Author Topic: 1986 250r long travel setup?  (Read 14200 times)
Re: 1986 250r long travel setup?
« Reply #15 on: January 25, 2019, 06:51:17 PM »
Like I mentioned above I've been in your shoes and had the same thought process you are going through. My R has +3 laeger LT up front with pep zps shocks. Out back I'm currently running a stock heart transplant. With a laeger -1 arm (88-89 length) And it all feels good to me.
Before this I was running +3 arms and triple rate tcs standard travel shocks. I couldn't really tell the difference other then the zps sat lower. Out back was the same set up.
If your going to be hitting trails I would suggest going with +2
« Reply #16 on: January 29, 2019, 10:14:22 AM »
If you've got the money for the LT setup in the front, then I don't see a reason why you shouldn't go that route.
No linkage available for the rear that will turn it into LT. You can go no-link, but as stated earlier you'll need to strengthen the upper shock mount considerably.
What type of riding are you doing?
