Author Topic: FRONT SHOCK UPGRADE  (Read 5255 times)
Offline meathead
FRONT SHOCK UPGRADE
« on: March 17, 2019, 08:52:41 PM »
Hello. Going to upgrade my front shocks. Seriously considering elka stage 5 fronts. Anybody running them? if so how do they measure up as far as comfort goes ?
Online Tbone07
Re: FRONT SHOCK UPGRADE
« Reply #1 on: March 18, 2019, 11:14:51 AM »
Well Joel Hetrick, and a host of other MX, XC, and desert racers use them. So unless Elka is passing them out like candy for free, i'd bet it's a great shock choice. I know they're the unofficial shock choice of Roll Design.
If you do go with Elka stage 5's I'd hit up Jedediah Bunch from Roll Design. He knows quite a bit about them.
I've only run HLS and PEP so i'm not directly familiar with them
« Reply #2 on: March 18, 2019, 12:49:07 PM »
any aftermarket shock will be an improvement over stock shocks. and any properly set up shock will be light years above that. i have only used PEP so i cant speak about elkas. if the pros are using them they must be pretty good.
« Reply #3 on: March 18, 2019, 01:09:00 PM »
I would get custom axis if i were buying new.  I have heard of too many having trouble getting elks dialed in.  that is the reason i went with custom axis.  I have also had HLS, and they are great shocks, however, not available anymore.
Offline Michael88R
« Reply #4 on: March 18, 2019, 04:10:09 PM »
Has axis switched to aluminum shock bodies yet?  Elka and Motowoz are both aluminum. Way lighter and better heat dissipation.
« Reply #5 on: March 18, 2019, 08:04:43 PM »
What does axis use to make their shock bodies?
Offline Michael88R
« Reply #6 on: March 18, 2019, 10:57:23 PM »
Most shocks had/have a steel body.
Offline Burns363R
« Reply #7 on: March 19, 2019, 07:40:09 AM »
mmmmm Motowoz......
« Reply #8 on: March 19, 2019, 01:27:42 PM »
mmmmm Motowoz......
Burns might be on to something.  seeing how he is still an active racer.
