Author Topic: Bottom/midrange pipe  (Read 9557 times)
« Reply #15 on: July 04, 2013, 10:36:44 PM »
Trx7
Offline supernutt
« Reply #16 on: July 04, 2013, 10:44:52 PM »
Haven't heard much on the lrd adjustable pipes. I did think about a trx7 also. My trx5 fits perfect so maybe the 7 would be the same fit
« Reply #17 on: July 04, 2013, 10:58:32 PM »
Brother to the 5 for more lower end and mid needs.
Offline GO OVRIT
« Reply #18 on: July 04, 2013, 11:03:27 PM »
Wih that porting and 215psi, you probably are better off focusing on a low-mid pipe and not worry as much about the topend over rev.  Generally more compression will move the torque curve lower in the rpm range.  All I have experience with are the trx5, trx9, lrd adjustable, and fmf and the trx5 works best for me.  Like snowmaker and derby said, Neil knows what works with the way he set it up.  I always trust what he tells me.
Offline GO OVRIT
« Reply #19 on: July 04, 2013, 11:09:08 PM »
Quote from: supernutt;562
The lrd seems pretty equal to the 5 through the low and midrange, but seems to sign off earlier.  There were some other variables in my comparisson though.  As far as the fit from esr pipes; they got the performance dialed in pretty good but the fitment is a crapshoot.  One might fit perfect and the next not so much.
