Workshop
Suspension and Chassis
Swing arm pivot bolt question
Topic: Swing arm pivot bolt question (Read 3848 times)
desertR
Total likes: 26
January 17, 2020, 03:04:16 PM »
Done
Last Edit: April 05, 2021, 12:02:15 PM by desertR
havinnoj
Administrator
Total likes: 185
Re: Swing arm pivot bolt question
January 17, 2020, 03:25:18 PM »
Pretty sure the OEM ones were drilled through the center anyways.. never ran one with a zerk like that.
Piney0
Total likes: 10
January 17, 2020, 11:31:09 PM »
The OEM bolts are hollow, It's not hard to modify it with holes drilled through the bolt allowing grease to get right up in the bearings. Glann Innovations sells modified bolts drilled & tapped with grease zerks. I like the idea personally.
croat1
Total likes: 943
January 19, 2020, 08:45:30 AM »
https://www.forums.trx250r.org/index.php/topic,2754.msg27228.html#msg27228
broken1
Total likes: 156
January 19, 2020, 01:54:12 PM »
Unless you drill holes in the bearing collars & bearing shells adding zerks to the swinger bolt & or the pivot end of the swinger won't allow grease to get to the bearings. If your doing it to keep the bolt greased to make it easy to remove than that's an option but cross drilling the bolt at the collars will obviously make it weaker.
(1 person liked this)
Workshop
