Author Topic: 431 puma clutch options  (Read 2974 times)
Offline beattyracing
« on: February 23, 2020, 08:26:22 PM »
Hey guys. What are you all running for your big bore pumas.? I use the clutch mods on my smaller 363’s but the puma is too much to hold. Lock out sling shot seems like the best option... any other ideas.?
2017 Laeger narrow #lastlaeger LED 363
2018 Walsh narrow LED 363
1986 TRX250r gusseted LED 363
Re: 431 puma clutch options
« Reply #1 on: February 23, 2020, 09:56:20 PM »
I don't have a puma. I do have a 391 that has a slingshot clutch. It holds just fine for me.
« Reply #2 on: February 23, 2020, 10:18:14 PM »
I'm running a slingshot on my 431. It's been doing good
« Reply #3 on: February 23, 2020, 10:45:50 PM »
Slingshot on whatever basket you want and if you need more then swap the balls for tungsten balls.  I did that on my 443 duner and Super.. balls are like $100 I think.
Offline supernutt
« Reply #4 on: March 24, 2020, 08:01:29 PM »
have you guys had any troubles with the gears lasting while using the sling shot lockup clutch?  Would seem that it would be way harder on the gears due to no slippage at all compared to a non lockup with stiffer springs.
« Reply #5 on: March 24, 2020, 10:58:07 PM »
I haven't had an issue on the dune puma nor on the drag puma.
