Author Topic: mechanical seal  (Read 2971 times)
Offline evaneyeball
mechanical seal
« on: March 02, 2020, 09:52:10 PM »
this is probably a stupid question but i had to take out the rubber/spring part of the mechanical seal to powder coat and i didnt take out the inner metal piece. and when i took out the rubber piece i accidentally broke it but i have a few other rubber and spring pieces from my past clutch cover and other mechanical seal. can i just put one of those in because the spring kind of locks in place and i dont really know how the mechanical seal works so this is most likely a stupid question. i can upload picture later
LED built 86 trx 350 CEO
81 ATC250r
Offline evaneyeball
Re: mechanical seal
« Reply #1 on: March 02, 2020, 10:26:25 PM »
hi had to feed goats. edit i dont know why there is two pics of the clutch cover but i dont know how to delete them and i didnt mean to even put one up
« Last Edit: March 03, 2020, 12:39:42 AM by havinnoj »
81 ATC250r
Re: mechanical seal
« Reply #2 on: March 03, 2020, 12:39:53 AM »
Fixed the images for you
Offline desertR
Re: mechanical seal
« Reply #3 on: March 03, 2020, 02:41:58 AM »
I would think the rust stain would answer all your questions---------------replace it, they are not expensive.
desertR
Re: mechanical seal
« Reply #4 on: March 03, 2020, 11:06:31 AM »
Just replace it. It's a cheap part and it's better to be safe than sorry.
Re: mechanical seal
« Reply #5 on: March 03, 2020, 11:47:31 AM »
I agree! It sucks to put everything together and then fire it up only to find out that you have a bad water pump seal.
Loren
