Author Topic: what paddle haulers do you run  (Read 7812 times)
Re: what paddle haulers do you run
« Reply #15 on: April 01, 2020, 03:22:13 AM »
Stock 13/39 gearing would be a good start & like mentioned go with steel sprockets. I like Sunstar sprockets but recently got a PBI front & it seems to be holding up as good as the Sunstar. For chains I also use DID but would recommend the x-ring over o-ring for less drag
« Reply #16 on: April 01, 2020, 12:25:14 PM »
What these guys are saying about DID X-Ring and steel sprockets is 100% spot-on.  I'd consider JT steel sprockets too.
For tires, it's preference.  I always preferred more side-wall of a 22x11-8 (or now-a-days more like 21x11-8) and with the higher rollout compensated by dropping about a tooth in the front (so 12-39 on a stock cyl motor) - which gets you back to about the same overall final ratio that 13-39 would have with a smaller rollout 20x10-10.
« Last Edit: April 01, 2020, 12:30:03 PM by havinnoj »
Offline Michael88R
« Reply #17 on: April 01, 2020, 12:39:50 PM »
12 tooth front wears really fast.  I prefer 13/41 or even 42 if you need lower gearing.
« Reply #18 on: April 01, 2020, 01:18:53 PM »
I ran 13/42 on my 310 for years with 21-12-8 9 paddle extremes. I had trouble with those paddles robbing power until I had Pete fix everything that whatshisnuts screwed up on my engine. After that my paddle/gearing/engine  combo was perfect! Keep in mind that I am a very manly man at 285lbs lol
Offline evaneyeball
« Reply #19 on: April 01, 2020, 01:27:45 PM »
so im think'in 13/41 gearing with some 8 paddle extremes and a 150lbs idiot. do yall agree on this or if i should change it and get diffrent gearing and/or paddles
LED built 86 trx 350 CEO
81 ATC250r
« Reply #20 on: April 01, 2020, 01:37:23 PM »
No.... If you are using a 20" tall tire and have 8 paddles per tire stick with stock gearing
« Reply #21 on: April 07, 2020, 10:17:40 PM »
Swingarm length is also a factor in traction.  I dune at St. Anthony and keeping the  front end down on choke cherry can be a challenge.  The last few trips I have run 7 paddle edges and I like them.  I probably could use a +2 swingarm.
Offline evaneyeball
« Reply #22 on: April 07, 2020, 11:21:28 PM »
i run a stock swing arm but i need to get a better hole drill then i will make my own +2. and i do ride winchester and planning to go to st. anthonys soon after this carona crap
81 ATC250r
