Author Topic: 1988 Trx resto/mod build  (Read 29569 times)
Offline jwraymond6
Re: 1988 Trx resto/mod build
« Reply #15 on: April 15, 2020, 10:31:49 PM »
Jason at fourwerx wasn’t sure of the size filter they used on the prototype airbox so I’ll need to figure that out.ill take some measurements and hopefully someone will have some input.he said it was a 4.5 inside diameter but a short length filter is needed.does anyone know of any manufacturers that I can check out that have sizing charts rather than machine specific filters?I haven’t really looked yet..Thanks for any input..
Try Garrett at fuel customs I’m sure he has different types of filters
Offline Action69
« Reply #16 on: April 21, 2020, 09:49:38 AM »
I got some more parts in.Durablue axle nuts,RTC radiator fins,,Duncan racing repack kit and chrome down turn end cap,NPM black throttle cover and 2 bolt silencer hanger.The regular single hole exhaust hangers and black brake resivour are currently out of stock.I should be picking up some parts from the vapor blaster tomorrow.I had him cleaning up front and rear durablue hubs,PT trx race pipe and silencer.When I got the PT pipe it had a raw finish with visible weld burns but had a light coat of surface rust and the silencer was quite dull.I mocked up the from a arms until I get the new. Bushings and bearings from JD performance,also mounted up the rear shock and linkage.Today I’ll clean up the swingarm and mount it up,I think I’ll order my bearing carrier as well so I can get the rest of the rear together.I still need to order flexx bars,tires,bunch of Oem hardware and few grommets.hand controls,anti vibe bar mounts,steering stem mount and a bunch of other random stuff.There are a few fourwerx bits I’d like to buy as well once they replenish their inventory.
I
Offline Action69
« Reply #17 on: April 21, 2020, 08:53:25 PM »
I just ordered my fourwerx hood and I’m picking up my parts from vapor blasting.they look great in the pictures
« Reply #18 on: April 21, 2020, 08:59:42 PM »
Those parts cleaned up nice!
Offline Action69
« Reply #19 on: April 21, 2020, 09:41:51 PM »
They did .Loren you should build a vapor blast cabinet.theres videos on YouTube on how to make one..
« Reply #20 on: April 21, 2020, 09:46:07 PM »
I will look into it
« Reply #21 on: April 21, 2020, 11:33:41 PM »
Parts look great! I'll have to look into building one as well. Maybe turn my small blast cabinet into one if it's possible.
Offline evaneyeball
« Reply #22 on: April 22, 2020, 12:11:19 AM »
Those parts look awesome
LED built 86 trx 350 CEO
81 ATC250r
Offline Action69
« Reply #23 on: April 23, 2020, 12:54:54 PM »
I just received some bits from Sonny Fricia.Billet shock resivour mounts and a set of gas tank mounts.
« Reply #24 on: April 23, 2020, 12:56:31 PM »
Sweeeet!
Offline Action69
« Reply #25 on: April 23, 2020, 06:48:29 PM »
« Reply #26 on: April 24, 2020, 04:58:43 PM »
I have this same blasting cabinet so for anyone else with a HF cabinet that wants to turn it into a vapor blasting cabinet here you go: https://m.youtube.com/watch?v=vz81iO-RWY4
Offline Action69
« Reply #27 on: April 24, 2020, 05:13:29 PM »
Nice Kevin ..
Offline Action69
« Reply #28 on: April 29, 2020, 06:52:50 PM »
I’ve been mocking up parts as they come in,I’m trying to make one order for the oem hardware I just havnt spent the time to go over the machine and parts diagrams to see what I’m missing.
Offline Action69
« Reply #29 on: May 01, 2020, 09:52:29 AM »
I received the Delron bushings I ordered from eBay being JD performance never got back to me about the replacement set up they sell,I was interested  In trying out their set up which used a bearing in between the two bushings.i finally got someone on the phone after multiple calls and two emails,when they did got back to me a few weeks ago they were out of the shop and were supposed to follow up with me to place the order,unfortunately that didn’t happenLast night I started to install the bushings but they were such a snug fit I put some dish soap on them and had to proceed with hammer ring each one in what a PIA,do you guys think a clamp or vice would work?its tough to get enough force on the inside bushings.I got one arm done last night but I’m hoping to find and easier way.Any input would be appreciated..
