Author Topic: 110 mix  (Read 7001 times)
Offline evaneyeball
110 mix
« on: June 09, 2020, 08:59:20 PM »
So I'm am breaking in my engine with dumonde tech and k and s 110 what oil mix should I use 20:1 or 32:1
LED built 86 trx 350 CEO
81 ATC250r
Re: 110 mix
« Reply #1 on: June 09, 2020, 09:10:23 PM »
I do the break in with the same mix ratio that I run normally. 40:1 is what I go with. If you normally run 32:1 then go with that. Oil ratio is all about your preference. 32:1-40:1 is very common.
Loren
« Last Edit: June 09, 2020, 09:12:43 PM by The norm »
Offline evaneyeball
Re: 110 mix
« Reply #2 on: June 09, 2020, 09:13:13 PM »
Ok I haven't mixed any yet and was waiting for a reply. I think I will go with 40:1
81 ATC250r
Re: 110 mix
« Reply #3 on: June 09, 2020, 09:22:50 PM »
Arlen most likely lubed the piston, wrist pin bearing, rod bearing, and main bearings  when he assembled the engine.  So be prepared for excessive smoke for a few minutes.
Re: 110 mix
« Reply #4 on: June 09, 2020, 10:24:36 PM »
Because of the fact most people run either 40:1 or 32:1 I mix mine in the middle at 36:1.
Offline evaneyeball
Re: 110 mix
« Reply #5 on: June 09, 2020, 10:41:37 PM »
I already mixed it at 40:1 but thanks for any input and I might try and mix at 36 and 32 next couple times
81 ATC250r
Re: 110 mix
« Reply #6 on: June 09, 2020, 11:50:30 PM »
Every time you change your oil ratio you may have to rejet. Less oil means more gas which is richer and the opposite for more oil....
So for simplicity sake pick a mix ratio and stick with it unless you have a oil related problem.
Offline evaneyeball
Re: 110 mix
« Reply #7 on: June 10, 2020, 12:24:58 AM »
ok then i will stick with 40:1 then. i got it running and its super crisp but the floats are sticking in my carb and then over flowing the bowl so tomorrow i will take my carb apart and check if the floats are either punctured or just way out of adjustment. its a cr500 carb i think. i will double check tomorrow.
81 ATC250r
Offline jwraymond6
Re: 110 mix
« Reply #8 on: June 10, 2020, 12:19:47 PM »
I run 32:1 either 32:1 or 40:1 is fine I know Honda required these motors to run 20:1 I believe when they was new but oil in 1986 compared to today’s oil is completely different today’s oils is a lot more refined then it was in the 80s
Re: 110 mix
« Reply #9 on: June 10, 2020, 12:42:40 PM »
I've ran R50 at 40:1 for years, no issues and plenty of lube.  Makes easy mixing (1 pint to 5 gal) is 3.2oz oil per gallon which is plenty with today's oils.
Re: 110 mix
« Reply #10 on: June 10, 2020, 01:52:20 PM »
Honda stated a premix ratio of 20:1 more as a cya for them to try & prevent people from under lubricating their engines & bringing them in for warranty on crank replacements. If people actually ran 20:1 they usually fouled a lot of plugs... Got my 86 in 88 shortly after my friend got his 88 new & we both always ran 40:1 with Klotz Benol back than.
