Author Topic: Grommets?  (Read 12100 times)
Offline shawnhart87r
Grommets?
« on: August 09, 2020, 01:42:35 PM »
I'm restoring my 87r and found home-made electrical tape grommets on the 2 pegs for the air box. Does anyone know where I can find two of these or if theres a company that makes aftermarket? They are part #28 on babbitsonline. Also looking for a good connecting tube from airbox to carb. Any help appreciated!
Online The norm
Re: Grommets?
« Reply #1 on: August 09, 2020, 02:20:32 PM »
I just ordered as set I found on Ebay. Other than that you could go to an Ace Hardware store or something similar and see what you can find.
Offline desertR
Re: Grommets?
« Reply #2 on: August 09, 2020, 04:02:29 PM »
I ordered a few from Babbit's, but it has been a few years ago. I have 1 or 2 for spares as I figured these would become NLA by the next time I needed some. I've seen then on Ebay also, no idea on quality, but they are a lot more expensive then OEM. Guess I better look for those, and put them somewhere I will remember.
desertR
Re: Grommets?
« Reply #3 on: August 09, 2020, 04:39:32 PM »
If your not going for a 100 point restoration you could use two of the front fender mounting grommets & modify them to work as the airbox grommets. I just measured both & there the exact same diameter & only .025" difference in height(fender grommets are slightly taller). The fender grommets are also still available from Honda for under $5 each, just have to cut the flanges down. 1st pic is a fender grommet on left & airbox grommet on right.
« Last Edit: August 09, 2020, 04:43:57 PM by broken1 »
Offline Action69
Re: Grommets?
« Reply #4 on: August 09, 2020, 04:49:02 PM »
There is a guy on eBay but theyre $30 for the pair
Re: Grommets?
« Reply #5 on: August 09, 2020, 05:41:36 PM »
[/quot
Just like Kevin stated or find used ones.
Offline desertR
Re: Grommets?
« Reply #6 on: August 09, 2020, 10:01:16 PM »
I guess I should order a few more from Babbits, while they are still available  :) :)
start a new list ? ;)
desertR
Re: Grommets?
« Reply #7 on: August 06, 2023, 11:37:40 AM »
Hey
Not sure if you found them. But if you look at Amazon they have some close to stock look a like.
Re: Grommets?
« Reply #8 on: August 07, 2023, 08:41:39 AM »
Langbolt found a solution
