Author Topic: ATC500R Missile  (Read 57076 times)
Offline rjt500r
Re: ATC500R Missile
« Reply #15 on: October 31, 2020, 09:38:20 AM »
Decided to build the Missile.
A couple of pics of the tear down and set the motor in place to start the surgery.
Re: ATC500R Missile
« Reply #16 on: October 31, 2020, 01:45:57 PM »
Going to be a sweet build! Do you think you will have it ready for the 2021 R meet ?
Offline rjt500r
Re: ATC500R Missile
« Reply #17 on: October 31, 2020, 04:37:39 PM »
It should be done in the next 2 or 3 months. All the parts are ordered and on the way. The forks are the only unknown at the  moment still not sure if I'm doing the inverted conversion or not.
Re: ATC500R Missile
« Reply #18 on: November 01, 2020, 12:47:00 AM »
I believe the ktm sx85 front forks have the correct travel. You just need to get them set up for the machine and your weight.
Loren
Offline rjt500r
Re: ATC500R Missile
« Reply #19 on: November 01, 2020, 10:00:02 AM »
Yeah the KTM forks are the correct length, having trouble finding someone with the triple clamps for the forks.
Re: ATC500R Missile
« Reply #20 on: November 01, 2020, 11:51:29 AM »
Yeah that's the trouble.  My buddy Luke researched forks and triples for his 86 ATC and he couldn't find anyone machining triples.  He is planning to machine his own when time allows.
Re: ATC500R Missile
« Reply #21 on: November 01, 2020, 01:24:31 PM »
You might have read this thread already but I found this on 3ww: http://www.3wheelerworld.com/showthread.php/51514-Crazy-inverted-tricks-on-a-ATCR250R!
Offline Action69
Re: ATC500R Missile
« Reply #22 on: November 01, 2020, 07:59:40 PM »
I’m pretty sure bvc trikes can machine the triples for whatever diameter fork leg your using..the guy who bought my trike frame had the triples in the pictures I posted machined for 2008 crf450r legs and they came from bvc with the matching axle and billet hub..he had a suspension guy shorten them and set them up for the build..
Offline 2Nubs
Re: ATC500R Missile
« Reply #23 on: November 02, 2020, 11:11:29 AM »
I misread and thought this was someone’s else’s thread lol
Rjt500, glad you decided to go through with it. Very cool
‘86 330
Offline rjt500r
Re: ATC500R Missile
« Reply #24 on: November 03, 2020, 10:04:56 AM »
[/quot
I don't have the equipment to machine my own, wish I did.
Offline rjt500r
Re: ATC500R Missile
« Reply #25 on: November 03, 2020, 10:05:40 AM »
I have seen that post. Not the direction I want to go.
Offline rjt500r
Re: ATC500R Missile
« Reply #26 on: November 03, 2020, 10:09:43 AM »
This will most likely be the direction I go … the BVC triples with the CRF forks... eventually. For now I'm going to re-spring the OEM forks. Put a big dent in the bank account already on this project.
Offline rjt500r
Re: ATC500R Missile
« Reply #27 on: November 03, 2020, 10:11:46 AM »
Thanks. Most all of the parts will be here this week and I can get started... of course pics will follow.
Offline rjt500r
Re: ATC500R Missile
« Reply #28 on: November 03, 2020, 07:22:26 PM »
Swingarm pivot bolt showed up today. Engine is positioned to line up with the swingarm jack shaft sprocket. Time to fab a swing arm spacer and engine mounts.
Offline rjt500r
Re: ATC500R Missile
« Reply #29 on: November 03, 2020, 07:26:48 PM »
more pics
