Author Topic: Champion beadlock mod  (Read 5857 times)
Offline Michael88R
« on: December 25, 2020, 10:17:14 PM »
I want to Mod this inner reinforcement ring both to lighten it up and improve the aesthetics. What do you guys think Is the best way to do it?  Design?  I’m going to dismount the tire and I have access to a lathe and mill.
« Last Edit: December 25, 2020, 10:19:21 PM by Michael88R »
Re: Champion beadlock mod
« Reply #1 on: December 26, 2020, 05:25:33 PM »
Maybe put them in a lathe & cut them back until the holes are gone than cut a saw tooth pattern on the remaining ring? Or maybe use a small hole saw to make a series of half round holes around it to make it look like a reverse sprocket?
Offline Michael88R
« Reply #2 on: December 26, 2020, 05:52:01 PM »
I was considering cutting it down so the existing holes are gone.
« Reply #3 on: December 26, 2020, 05:54:57 PM »
Manual or CNC mill?  I’d clamp the wheel on a rotary table and then mill some slots...just like the currently available beadlock rings.
If you have a CNC mill you can get creative on the type of pockets you can mill.
« Reply #4 on: December 26, 2020, 05:55:58 PM »
Like these....
« Reply #5 on: December 26, 2020, 06:02:30 PM »
To turn the ID of the wheel on a lathe you can use an old axle as an arbor (with a hub).  Cut the old axle at the bearing surface.  Chuck it up in the the lathe with a center in the tail stock.  Turn the OD to get the taper out of it.  Now you have a good round diameter to chuck up on (Shorten it up some though).
« Reply #6 on: December 26, 2020, 06:11:22 PM »
Cool design
Offline Michael88R
« Reply #7 on: December 26, 2020, 06:37:08 PM »
Manual.  I was thinking slots would look cool.  We have an experienced Machinist at work but I don’t know how much time he is willing to spend.  I think we have a radius fixture.
Offline Michael88R
« Reply #8 on: December 26, 2020, 06:43:17 PM »
If I wanted to make them really fancy I could probably send them to OMF.
Offline 2Nubs
« Reply #9 on: December 27, 2020, 09:15:32 AM »
I had some OMF rings on my rock crawler and they are very proud of them lol. Think they were a couple hundred bucks each but man were they strong and looked great. Seems their quad wheels are nearly as expensive as the Jeep wheels.
‘86 330
Offline Michael88R
« Reply #10 on: December 27, 2020, 10:15:45 AM »
Yes they are pricey $$$
« Reply #11 on: December 28, 2020, 12:48:57 PM »
Shoot if you have a mill then your possibilities are endless. Like an adult etch a sketch. Post up what you come up with. Sounds like a fun project
Offline Action69
« Reply #12 on: December 28, 2020, 02:46:29 PM »
Here are the rings on my itp c2 rims..
Offline Michael88R
« Reply #13 on: January 04, 2021, 12:05:32 AM »
Three options.  Which looks best.  I’m thinking #1.  All the black area would be machined #1 would remove the most weight, still be plenty strong and have the most open area for sand to escape.
« Last Edit: January 04, 2021, 12:10:42 AM by Michael88R »
« Reply #14 on: January 04, 2021, 01:16:34 PM »
i like #1 but without the really big slot. Maybe make the slots like a long trapezium. /          \
