Author Topic: CR250 CDI Location  (Read 3545 times)
CR250 CDI Location
« on: January 16, 2021, 08:40:27 PM »
Hey there fellas.  I am trying to mount a CR250 CDI in a sensible way. Could someone please post a picture of their favorite mounting location.
Thanks Loren
Re: CR250 CDI Location
« Reply #1 on: January 16, 2021, 09:07:42 PM »
Stock location
Offline Action69
« Reply #2 on: January 16, 2021, 09:16:10 PM »
I was wondering the same thing..
« Reply #3 on: January 16, 2021, 09:48:42 PM »
Loren, I’m assuming your asking for the 1999 set up.  When I had it I did not have (could not locate) the mounting rubber for it so I used a piece of rubber sheet and zip tied it to the upper frame rail....not ideal but I was pressed for time.  Since that time I’ve located the rubber grommet for the 1999 CDI but not looked into mounting.  The 1999 is physically bigger than 2000 on up CDI.
The pic I posted is a 2000+ CDI.
I’ll head out to the garage in the morning and investigate further.
« Reply #4 on: January 16, 2021, 09:50:49 PM »
Thanks Joe. I am trying to mount the cdi with the oem rubber and I may have to use zip ties
« Reply #5 on: January 16, 2021, 10:13:18 PM »
If you have some dense rubber sheet & some vulcanized CA glue you could easily make an isolator.
« Reply #6 on: January 17, 2021, 08:03:53 PM »
Loren, how about utilizing a coil mount?
« Reply #7 on: January 17, 2021, 08:05:21 PM »
Sorry I couldn’t get out to the garage today to tinker with mounting a 99 setup
« Reply #8 on: January 17, 2021, 08:31:59 PM »
I was thinking about something like that Joe. I have the plastic off my R and will come up with some ingenious way lol
« Reply #9 on: January 17, 2021, 10:08:45 PM »
Stock location like Joe's pic showed.  I do add a zip tie around the "holder hook bracket thing" (whatever it's called) that the rubber slips over to prevent the rubber from ever sliding off on it's own.
« Reply #10 on: January 17, 2021, 10:29:43 PM »
With the 99 Loren it is a little shorter harness than 00 and 01. Have to run it just right to reach stock mount.
