Author Topic: Kicker shaft  (Read 7795 times)
Kicker shaft
« on: January 21, 2021, 09:18:09 AM »
The early 85 atc250r engines had a shorter kicker shaft that caused the kicker to rub the clutch cover.  The change  to a longer shaft was changed sometime during production (1985).  Unfortunately I do not know at what exact serial number the change occurred.
« Last Edit: January 23, 2021, 06:07:20 PM by croat1 »
Offline Braaaping247
Re: Kicker shaft
« Reply #1 on: January 23, 2021, 04:43:48 AM »
Re: Kicker shaft
« Reply #2 on: January 23, 2021, 05:46:16 PM »
Great info! now im curious and want to see what I have. Honda gave .9 seams generous
Re: Kicker shaft
« Reply #3 on: January 25, 2021, 03:40:09 AM »
Re: Kicker shaft
« Reply #4 on: March 09, 2021, 12:21:54 AM »
This is not what we want to happen.
Offline evaneyeball
Re: Kicker shaft
« Reply #5 on: March 09, 2021, 12:47:04 PM »
Something else interesting is that somewhere between 86 and 89 they changed the cover also so that you don't have to run a collar on the shift shaft
LED built 86 trx 350 CEO
81 ATC250r
Re: Kicker shaft
« Reply #6 on: March 09, 2021, 03:26:06 PM »
I believe that was in 1988. The changed the gear and cover.
Re: Kicker shaft
« Reply #7 on: March 09, 2021, 09:13:03 PM »
“Early” 1985
Re: Kicker shaft
« Reply #8 on: March 09, 2021, 09:15:40 PM »
“Updated” 1985 and newer
Offline Banshee330
Re: Kicker shaft
« Reply #9 on: March 14, 2021, 08:43:32 PM »
Are there any aftermarket company’s making the kick starter shaft?
Re: Kicker shaft
« Reply #10 on: March 14, 2021, 09:02:42 PM »
Not in oem length.  I believe a company called Direct Drive does or did make some longer ones to clear a lock up clutch cover.
Offline Banshee330
Re: Kicker shaft
« Reply #11 on: March 16, 2021, 08:32:23 PM »
I found a used kicker shaft on eBay today for 14 bucks. Hope it works, I got a few spline teeth missing. Also the gear shifter shaft have teeth missing too. Seller said splines were good. Also said it was only for 86-87 model.After reading this I’ll measure the shaft length, hope for the best.
Re: Kicker shaft
« Reply #12 on: March 17, 2021, 01:15:14 PM »
Pretty sure the 85-86 atc & 86-89 trx all have the same shift shaft
Re: Kicker shaft
« Reply #13 on: April 05, 2021, 04:43:45 AM »
Ya the early shafts don't clear a esr qc cover when I built the puma. I used take out parts on it. First time I went to kick it. It dug into the cover. Had to put a different style in
Re: Kicker shaft
« Reply #14 on: April 05, 2021, 10:01:08 AM »
Man Gene I bet that was a great feeling on a new build!
