Author Topic: New member here  (Read 11733 times)
Offline Banshee330
New member here
« on: March 08, 2021, 07:43:26 AM »
Hi guys, my cousin has finally decided to sell me his 250r  the motor blew up in 1999. This beast has been sitting in a shed for 20 plus years. My son and I  going to take on the project and build this quad. Hoping there are parts available for this journey . Hopefully we can wake up this sleeping legend.
Re: New member here
« Reply #1 on: March 08, 2021, 08:00:11 AM »
Congratulations! I have been building a couple 250R'S with my two boys and it has been a blast! Just a few words of caution...... I started with a single 250R for myself and then 2 for my boys, now I have an ATC build going and enough parts to build a couple more TRX's. My point is that these things are addictive lol. Good luck with your build and have fun with your son!
Loren
Re: New member here
« Reply #2 on: March 08, 2021, 08:11:30 AM »
Welcome to org.
Congratulations on acquiring the greatest quad ever sold.  So cool that your working on the project with your son.  Please when you get started start a build post that way we can see your progress.  We will help with your journey any way we can.
Re: New member here
« Reply #3 on: March 08, 2021, 08:11:45 PM »
Welcome. Let's see some pictures of this barn find
Offline Banshee330
Re: New member here
« Reply #4 on: March 09, 2021, 11:40:28 AM »
Hi guys, went by my cousin’s and snapped a few pics. I have located the motor and plan on picking it up tomorrow.
Re: New member here
« Reply #5 on: March 09, 2021, 12:08:05 PM »
Nice.  Can’t wait to see it come together.
Offline evaneyeball
Re: New member here
« Reply #6 on: March 09, 2021, 12:37:47 PM »
That's a good beginning, alot of potential there. And welcome to .org
LED built 86 trx 350 CEO
81 ATC250r
Re: New member here
« Reply #7 on: March 09, 2021, 05:23:00 PM »
Welcome to .Org!
Re: New member here
« Reply #8 on: March 09, 2021, 08:14:21 PM »
Farm fresh. I love it.
Offline Banshee330
Re: New member here
« Reply #9 on: March 10, 2021, 08:41:56 PM »
Well I picked up the motor today. Was really hoping it had not been taken apart. Well here’s the pics of the motor, I am sure there are things missing, but it looks like most of it is there.  The middle cases where the side of the crank is of some concern, any advise on repairing or should it be left alone. One case is cracked, the other is very rough.
Re: New member here
« Reply #10 on: March 10, 2021, 09:55:02 PM »
You are getting the full experience.
Regarding the cases, I doubt they are cracks. Very common to have casting marks around the bearings. If you take a real close look at them you will probably see the casting. Look real close at the chamfer around the main. If it is a crack it would propagate through the chamfer.
The other case looks like something for in-between the crank and the case. Piston maybe? Possible it have a crank that lost a tin
Awesome build. I am jelly
Re: New member here
« Reply #11 on: March 10, 2021, 10:39:08 PM »
I 2nd the casting flaws. Give it a good scratch. It should be solid. Look at the good side you, don't have to take it apart!
Offline 4WHLr
Re: New member here
« Reply #12 on: March 10, 2021, 11:14:31 PM »
I have a set that looks similar. I wanted to send them off to be looked at to be sure, but never did. I cant see anything on the other side, or anything into the bearing bore either. mine seems to extend up towards the cylinder dowel area too.
I've watched many go through ebay without any mention at all FWIW.  So it does seem at least a little common, from what i've seen.
I'm curious to others opinions as well.
[img][img]
« Last Edit: March 10, 2021, 11:29:21 PM by 4WHLr »
1986 TRX275R PC2000
Offline evaneyeball
Re: New member here
« Reply #13 on: March 11, 2021, 01:49:53 AM »
My set has a casting mark that looks like a crack too but I don't have a picture and its together so out of luck on the pictures lol
81 ATC250r
Re: New member here
« Reply #14 on: March 11, 2021, 05:08:51 AM »
Welcome to org. It's cool that it's been in your family & you know the history of it... When you remove the crank bearings inspect the pockets & as long as it doesn't look like there's a crack in there than that's most likely just a casting mark like others have said. By the way that engine & the fuel tank is 88 or 89. You can look up the number on the engine to know exactly.
« Last Edit: March 11, 2021, 05:13:03 AM by broken1 »
