Author Topic: Mikuni Tmx 38  (Read 5444 times)
Offline dp250r
Mikuni Tmx 38
« on: March 15, 2021, 09:51:50 AM »
I bought this mikuni tmx 38 for $40.Came with twist throttle and cable but no jets.My buddy I got it from said its from an 02 cr250r. I've been reading post on here and couple other sites.Im going to order the s-8 needle tube and some jets from jets r us.Im going to try this carb on my air-cooled 300r with Flotec porting and my 85 250r .
Re: Mikuni Tmx 38
« Reply #1 on: March 15, 2021, 10:40:43 AM »
I think the 02 came with the S-8 needle jet already installed, the 01 had the S-9 I know for sure which is what gave it a bad reputation as being a junk carb. On my buddy's 01 CR all I did was change to an S-8 needle jet, 400 main & I believe I used a 32.5 pilot & that bike became a completely different animal!... One thing about Mikuni's though if you don't like tinkering on carb's don't buy one.
Offline dp250r
Re: Mikuni Tmx 38
« Reply #2 on: March 15, 2021, 10:57:53 AM »
Carbs aren't my favorite thing to do but I don't mind tinkering with them.Before I got into trikes and atvs I messed with motorcycles and snowmobiles some machines  had old round slide Mikunis I did pretty well with those.I checked the needle tube and its an s-9.It was laying in the bottom of the box the carb came in.Could be 01 carb.  broken1 thanks for the info.
« Last Edit: March 17, 2021, 03:46:41 PM by dp250r »
Offline dp250r
Re: Mikuni Tmx 38
« Reply #3 on: March 15, 2021, 03:31:47 PM »
I picked this tm 38 up a few years ago with a DG aircooled 250r intake. It is missing the cap and slide valve .I'm thinking about buying the parts for it.Jets r us have them.Price would be around $ 120 for everything needed.
« Last Edit: March 16, 2021, 02:30:37 PM by dp250r »
Offline Michael88R
Re: Mikuni Tmx 38
« Reply #4 on: March 16, 2021, 10:09:15 AM »
My Tmx carbs have “tmx” cast into the side of it.
Offline dp250r
Re: Mikuni Tmx 38
« Reply #5 on: March 17, 2021, 03:51:01 PM »
The carb in top pic has tmx on the side of the slide throat.The carb in the other two pics is a tm carb according to jets r us site when I Google the numbers on the carb. The pic in this post is the parts schematic of the tm carb.
« Last Edit: March 17, 2021, 03:57:15 PM by dp250r »
Re: Mikuni Tmx 38
« Reply #6 on: March 17, 2021, 10:35:07 PM »
@Jerry Hall
Had a really good write of the TM carb and the difference between it and the TMX.
« Last Edit: March 17, 2021, 10:36:55 PM by Skeans1 »
