Author Topic: Bearing removal  (Read 31759 times)
Offline Banshee330
Re: Bearing removal
« Reply #60 on: May 04, 2021, 07:24:03 PM »
Thanks Joe! Ok fellas she’s holding 5.5 psi, well it has a slow , slow , leak around this brand new intake boot. Lost about 2 psi, in about 12 minutes. Probably gonna hone the surface finish of the metal and try again tomorrow after work.
« Last Edit: May 04, 2021, 07:47:39 PM by Banshee330 »
Re: Bearing removal
« Reply #61 on: May 04, 2021, 08:34:34 PM »
An air leak that small will not effect the jetting, the idle quality or a piston seizure.
Offline Banshee330
Re: Bearing removal
« Reply #62 on: May 07, 2021, 06:51:11 AM »
Thanks Jerry for that information. I got a question about long term storage on the motor. I have it built, but I am working on the rest of the quad. Any advice on motor storage while the rest of the quad is being built. Should I put oil in it and turn it over every so often? Maybe a cap full of 2 stroke oil in spark plug hole? Keep it inside house, better than in garage?
Re: Bearing removal
« Reply #63 on: May 07, 2021, 11:32:01 AM »
Put it on a Pumashine engine stand & set it on your coffee table until you need it. They make great living room art
Offline Banshee330
Re: Bearing removal
« Reply #64 on: May 24, 2021, 07:26:11 PM »
Hi guys been working a lot of shutdowns and there’s no end in sight till July. I see slot of ignition coils online very cheap. Any thoughts or anybody try them? Any recommendations? Son is picking up frame and swing arm this week from getting powder coated! New parts are starting to pile up. Sad I haven’t had time to bond with the build lately.
Re: Bearing removal
« Reply #65 on: May 24, 2021, 07:45:15 PM »
OEM is what I’d buy.
Offline Texas30cal
Re: Bearing removal
« Reply #66 on: September 03, 2021, 01:12:51 AM »
Used this little jewel to remove the tiny clutch shaft bearings! Son asked last night, dad how comfortable are you building this motor, I said not sure never built one before.
What brand is that long reach blind hole puller?I can’t seem to find one 10mm dia and long enough to reach the bottom clutch shaft bearing.
