Workshop
Suspension and Chassis
Hardkor front hub rebuild items
Topic: Hardkor front hub rebuild items (Read 9020 times)
croat1
Total likes: 947
December 24, 2021, 09:36:01 PM »
Here are the part numbers and quantities when rebuilding Hardkor front hubs.
Last Edit: March 10, 2023, 05:50:36 PM by croat1
croat1
Total likes: 947
Re: Hardkor front hub rebuild items
August 29, 2024, 11:55:31 AM »
Loren, these are the items you need.
The norm
Total likes: 327
August 29, 2024, 06:35:14 PM »
Thanks Joe!!
croat1
Total likes: 947
August 29, 2024, 07:09:53 PM »
Quote from: The norm on August 29, 2024, 06:35:14 PM
Thanks Joe!!
Your welcome
Langbolt
Total likes: 62
August 29, 2024, 09:47:09 PM »
@croat1 @The norm - Hey guys.....since I'm always looking for bearings I thought I'd look up the ones Joe posted.....Are you aware that those Timken Bearings specified are METRIC inner bearing and IMPERIAL outer ? No wonder everyone else with HARDKOR hubs could never find a matching set of Metric bearings for both.
Cup & Cone - 32004x = 20mm Bore 42mm OD 15mm Width
https://cad.timken.com/item/tapered-roller-bearings-ts-tapered-single-/tapered-roller-bearings-ts-tapered-single-metric/32004x-2
Cup - A4138 = 34.989mm OD 8.73 Width
https://cad.timken.com/item/tapered-roller-bearings---single-cups/tapered-roller-bearings---single-cups---imperial/a4138
Cone - A4059 = 14.989 Bore 10.98 Width
https://cad.timken.com/item/tapered-roller-bearings---single-cones/tapered-roller-bearings-single-cones-imperial/a4059
Looks like that seal CR10937 has been Discontinued.....Here's the Replacement 28X44X6 HMSA7 P
https://www.skfextranet.com/crsealsfinder/datasheet.aspx?s=28X44X6+HMSA7+P
Also, The OD of the CUP is smaller than the SEAL (44mm)
Or Does the HUB have a step...so the Seal is bigger.
Loren, can you post some pics without the bearings & seals?
John
Last Edit: August 30, 2024, 08:38:08 AM by Langbolt
Workshop
