Author Topic: My Junk  (Read 37245 times)
My Junk
« Reply #75 on: November 08, 2014, 02:23:56 PM »
i have a question for you guys and maybe i can learn something in the process. is it not better than have the temp gauge where it exits the engine, rather than the return line from the radiator bottom ?  i see nearly everyone in the banshee scene doing this also. doesnt make much sense to me but maybe im missing something here
My Junk
« Reply #76 on: November 08, 2014, 07:01:17 PM »
Quote from: udontknowme;45665
Multiple choice.
A temp. gauge on the coolant line returning coolant from the radiator to the engine does what?
     a.  Gives the temperature of the coolant returning to the engine.
     b.  May give an indication of how well the radiator is working.
     c.  Does not really tell you what temperature the engine is running.
     d.  If the gauge shows a temperature change it means the sensor has coolant flowing over it.
     f.  It may be the most convenient location for the sensor and is aesthetically pleasing to the eye.
     g.  The 1st guy to install a sensor put it in the wrong place and everyone else copied him thinking the 1st guy knew what he was doing.
My Junk
« Reply #77 on: November 08, 2014, 09:46:19 PM »
all of the above :excitement:
this wasnt a poke at atvfan28. just curious if i had overlooked a good reason to have the gauge located on the return line
Offline atv fan 28
My Junk
« Reply #78 on: November 08, 2014, 09:55:19 PM »
I put mine where it is cause its easier to read. Plus it will read the same if i put it on the other line.Even though some people won't believe it.
My Junk
« Reply #79 on: November 08, 2014, 09:56:02 PM »
Quote from: Jerry Hall;45679
Multiple choice.
It seems to me that you'd want to have 2....one exiting the motor and one exiting the radiator
Nice "junk" BTW :smoking
My Junk
« Reply #80 on: November 08, 2014, 09:59:27 PM »
now im confused. for example  how can it go in 200 and come out 200 ?
My Junk
« Reply #81 on: November 10, 2014, 12:33:00 PM »
Multiple choice.
In most cases it would have to say all of the above
My Junk
« Reply #82 on: November 10, 2014, 12:45:38 PM »
Quote from: udontknowme;45687
Most of the time you cannot position the temp. gauge in a location where you can look at it while moving at a high enough speed where the radiator is doing much cooling.  By the time you slow down enough to where you can focus on the gauge and get a precise reading, the radiator as stopped cooling and the temperature exiting the radiator is very close to the temperature entering the radiator.  The small inline glycerin filled gauges were not designed to give laboratory accuracy but to give you a ball park idea of the temperature of the coolant in the line it is monitoring.
Under average riding conditions, the temperature exiting the radiator is less than 10 degrees cooler than the temperature of the coolant entering the radiator, unless the radiator has a huge frontal area, the air speed through the radiator is very high and the ambient temperature is very cold.
My Junk
« Reply #83 on: November 10, 2014, 04:03:40 PM »
it makes sense if the bike was stationary both temps be be about the same. seems like if it was moving however there would be more than a couple degree difference. then again ive never tried 2 gauges so ill take your word for it
My Junk
« Reply #84 on: November 10, 2014, 05:38:53 PM »
Quote from: udontknowme;45758
   ............................ seems like if it was moving however there would be more than a couple degree difference. then again ive never tried 2 gauges so ill take your word for it
This is the main reason that guys crawling around in 1st gear for more than a few minutes tend to have heating problems.  Most of these radiators do not get much air threw them running below 15 mph.
Offline atv fan 28
My Junk
« Reply #85 on: April 20, 2015, 10:21:53 PM »
Almost ready Gator Nationals in Gilbert Louisiana.
Offline oldschoolr
My Junk
« Reply #86 on: April 20, 2015, 10:44:47 PM »
That's beautiful Wayne,  even if Daniel Allen beats ya you'll still have the best looking bike there.
My Junk
« Reply #87 on: April 21, 2015, 12:18:44 AM »
good luck weezy
My Junk
« Reply #88 on: April 21, 2015, 11:37:38 AM »
dead. sexy.
Offline atv fan 28
My Junk
« Reply #89 on: August 23, 2015, 12:07:36 PM »
