Author Topic: Vapor honing  (Read 5976 times)
Vapor honing
« on: February 26, 2022, 04:01:21 PM »
Looks like these guys do nice work.  Just passing info along.
Re: Vapor honing
« Reply #1 on: February 26, 2022, 04:01:59 PM »
Looks good.
Re: Vapor honing
« Reply #2 on: February 26, 2022, 04:02:32 PM »
Last pics.
Re: Vapor honing
« Reply #3 on: February 26, 2022, 08:23:53 PM »
Offline bushwesl
Re: Vapor honing
« Reply #4 on: February 27, 2022, 02:37:08 AM »
I’ve used DBC Racing for all of my vapor honing. Blake is meticulous and is always a pleasure to work with. They also do engine rebuild services, and deal in OEM and aftermarket parts too. I feel very fortunate to have DBC Racing local to me in West Michigan.
« Last Edit: February 27, 2022, 03:40:13 PM by bushwesl »
Re: Vapor honing
« Reply #5 on: February 27, 2022, 02:51:22 PM »
I’ve used DBC Racing for all of my vapor honing. Blake is meticulous and is always a pleasure to work with. They also do engine engine rebuild services, and deal in OEM and aftermarket parts too. I feel very fortunate to have DBC Racing local to me in West Michigan.
I’ve met Blake a few times at Silverlake.  Yes I agree he’s very meticulous in all his work.
Offline bholzgen
Re: Vapor honing
« Reply #6 on: February 28, 2022, 08:47:59 AM »
Thank you for the kind words Wes and Joe!
If anyone is looking to get some vapor blasting done shoot me an email at blakeh.dbcracing@gmail.com
2002 Roll Design Lobo MX
2002 Laegers CRF450R Hybrid
1985 ATC 70
Offline bholzgen
Re: Vapor honing
« Reply #7 on: February 28, 2022, 09:18:45 AM »
Here are some photos of what we vapor blasted this week and last.  Keep in mind engines must be 100% disassembled before vapor blasting.  Blasting a complete engine is too risky as media will ALWAYS find its way in!
1985 ATC 70
Offline atvmxr
Re: Vapor honing
« Reply #8 on: February 28, 2022, 11:33:45 AM »
that was going to be my question.  so all the bearings got to be pulled/replaced?  Has anyone figured out a good way to change out that clutch arm bearing in the left case?
Offline bholzgen
Re: Vapor honing
« Reply #9 on: February 28, 2022, 04:16:23 PM »
Yes, all bearings must be pulled prior to vapor blasting.  With my blind puller I can get the upper clutch arm bearing out but the lower stays in the cases.  I have a verity of small rubber plugs that I use to block off all of the holes / passages and bearing bore for that specific area of the case.  Works like a charm!
1985 ATC 70
