Author Topic: TRX450R wires setup on Trx250r  (Read 3628 times)
« on: March 02, 2022, 11:04:31 AM »
I was wondering if anyone converted the TRX450r wiring to a TRX250r? I only ask because the CDI for TRX250r is so hard to find these days.
Re: TRX450R wires setup on Trx250r
« Reply #1 on: March 02, 2022, 04:35:52 PM »
I’m thinking your asking about a complete trx450 electrical system on a trx250R?  It won’t work.  Yes oem Trx250r cdi’s are hard to find and expensive when you do find them.  If used you can only hope they work.  I’ve seen used ones sell for $200-$250 lately.  I’ve seen a few new sell for about $500.
I’d go with a Zeeltronic CDI (then send your stator to Dave Moore).
« Last Edit: March 03, 2022, 04:30:44 AM by croat1 »
« Reply #2 on: March 02, 2022, 10:38:30 PM »
A 4-stroke ignition triggers half as fast as a 2-stroke ignition
« Reply #3 on: March 03, 2022, 09:05:01 AM »
Thank you guys.
Offline robjust
« Reply #4 on: March 11, 2022, 08:02:54 AM »
Joe is spot on. Zeel has a programmable CDI, that you can fine tune for your application, and can run 2 different maps on. You can switch tunes by a selector on the handlebars. You very likely are already running, resistor plugs, but with the Zeel you want to make sure you do. If you have a "R" in your plug number then it should be a resistor plug.
